Ir para o conteúdo principal
How to Repair A Wet Book
O que você precisa
  1. How to Repair A Wet Book, How to Repair A Wet Book: passo 1, imagem 1 %32
    • Be cautious when handling wet books, as books are very fragile when wet and you can accidentally damage front cover, pages, and/or spine.
    • If you do not have time to fix it, immediately put it in a Ziplock bag and place in freezer until you're ready. When you are ready to fix it, lay it on the table and leave it until it thaws.
    • Cover table with plastic sheet or newspapers.
  2. How to Repair A Wet Book: passo 2, imagem 1 %32
    • Lay the book down with the front cover facing up. Place a paper towel over the cover and gently press down on the book.
  3. How to Repair A Wet Book: passo 3, imagem 1 %32 How to Repair A Wet Book: passo 3, imagem 2 %32
    • Be very careful when opening the book, as the spine is very fragile.
    • Gently opening the book to a shallow angle, place paper towels every 10-20 pages in the front half of the book. Place a paper towel on the front cover and press down gently.
  4. How to Repair A Wet Book: passo 4, imagem 1 %32 How to Repair A Wet Book: passo 4, imagem 2 %32
    • Similarly to step 3, gently open the book to a shallow angle and place paper towels in every 10-20 pages towards the last half of the book. Place a paper towel on the front cover and press down.
  5. How to Repair A Wet Book: passo 5, imagem 1 %32
    • Stand the book up, heads or tails, with the pages fanned out.
  6. How to Repair A Wet Book: passo 6, imagem 1 %32
    • To speed up the drying process, leave a fan blowing on it.
  7. How to Repair A Wet Book: passo 7, imagem 1 %32 How to Repair A Wet Book: passo 7, imagem 2 %32
    • If after the book has dried the pages are wavy, lay the book flat and place a board on top of it, along with a couple of heavy books (on top of the board) to help flatten them out. Leave it like this until the pages are completely flattened.
  8. How to Repair A Wet Book: passo 8, imagem 1 %32
    • Great job! The book is now restored to its original condition. Happy reading!
Linha de Chegada
3 outras pessoas executaram este guia.
2Comentários do guia
because im in middle school. and it is sters full with wet books
Hazen Harwood - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 137
Ao todo: 2,087
