Ir para o conteúdo principal
How to Repair A Garden Walkway With Concrete Slabs
O que você precisa
  1. How to Repair A Garden Walkway With Concrete Slabs, How to Repair A Garden Walkway With Concrete Slabs: passo 1, imagem 1 %32 How to Repair A Garden Walkway With Concrete Slabs, How to Repair A Garden Walkway With Concrete Slabs: passo 1, imagem 2 %32
    • Use a cultivator machine to dig the soil which will make it smoother to the surface and level everything out.
  2. How to Repair A Garden Walkway With Concrete Slabs: passo 2, imagem 1 %32 How to Repair A Garden Walkway With Concrete Slabs: passo 2, imagem 2 %32
    • Use a rake to make the soil more leveled out to the surface.
    • Remove any extra soil with a shovel if needed.
  3. How to Repair A Garden Walkway With Concrete Slabs: passo 3, imagem 1 %32 How to Repair A Garden Walkway With Concrete Slabs: passo 3, imagem 2 %32 How to Repair A Garden Walkway With Concrete Slabs: passo 3, imagem 3 %32
    • Apply the first layer of limestone screening mixture, making sure it is even around the area.
    • Insert the first slab tile.
  4. How to Repair A Garden Walkway With Concrete Slabs: passo 4, imagem 1 %32 How to Repair A Garden Walkway With Concrete Slabs: passo 4, imagem 2 %32
    • Apply some more of the mixture and then insert the second slab tile.
  5. How to Repair A Garden Walkway With Concrete Slabs: passo 5, imagem 1 %32 How to Repair A Garden Walkway With Concrete Slabs: passo 5, imagem 2 %32
    • Apply third and final slab.
    • If needed, add some extra soil or the limestone screening mixture to make it even with the other two slab tiles.
  6. How to Repair A Garden Walkway With Concrete Slabs: passo 6, imagem 1 %32
    • Insert a 65-inch cedar wood border to align with the rest of the walkway.
    • Measure the area beforehand to know exactly how much cedar wood border you need.
  7. How to Repair A Garden Walkway With Concrete Slabs: passo 7, imagem 1 %32 How to Repair A Garden Walkway With Concrete Slabs: passo 7, imagem 2 %32 How to Repair A Garden Walkway With Concrete Slabs: passo 7, imagem 3 %32
    • Clean off the excess debris with your good ol' broom and wash it off with the garden hose to make it nice and shiny.
Conclusão
This guide will help you do this project in a safe and efficient manner. It will also give your garden walkway a more appealing look!
Adnan Hasan
Membro desde: 07/06/20
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 325
