Ir para o conteúdo principal
How to Repair A Broken Hip In A Plastic Doll
O que você precisa
  1. How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: passo 1, imagem 1 %32 How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: passo 1, imagem 2 %32
    • Determine where your doll is broken: is it at the knee? Hip? Arm?
    • If it’s broken at the knee, as marked in the second photo, unfortunately this guide will not help as it is a different kind of joint.
  2. How to Repair A Broken Hip In A Plastic Doll: passo 2, imagem 1 %32 How to Repair A Broken Hip In A Plastic Doll: passo 2, imagem 2 %32
    • If the ball is still inside the leg, remove it with pliers.
  3. How to Repair A Broken Hip In A Plastic Doll: passo 3, imagem 1 %32
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter.
    • Do not leave fire unattended. The metal will be hot, so please don't touch it with your bare skin.
  4. How to Repair A Broken Hip In A Plastic Doll: passo 4, imagem 1 %32
    • With the hot sewing needle, make a small hole in the center of the broken off ball. Make sure the needle is straight.
    • This may take a few attempts and a few needles.
    • Heating up the plastic will result in some fumes. Perform this step in a well ventilated area.
  5. How to Repair A Broken Hip In A Plastic Doll: passo 5, imagem 1 %32
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter. (This is a repeat of Step 3.)
  6. How to Repair A Broken Hip In A Plastic Doll: passo 6, imagem 1 %32 How to Repair A Broken Hip In A Plastic Doll: passo 6, imagem 2 %32
    • With the hot sewing needle, make a small hole in the peg of the hip. Make sure the needle is straight. Leave the pin inside.
  7. How to Repair A Broken Hip In A Plastic Doll: passo 7, imagem 1 %32 How to Repair A Broken Hip In A Plastic Doll: passo 7, imagem 2 %32
    • Remove the pin from the broken off ball joint with a pair of pliers.
  8. How to Repair A Broken Hip In A Plastic Doll: passo 8, imagem 1 %32 How to Repair A Broken Hip In A Plastic Doll: passo 8, imagem 2 %32
    • Using the pliers, cut the pin in the hip section to the appropriate length to fit into the hole made from Step 6.
    • Test the needle length by fitting the ball joint pieces together. The needle should be completely covered.
    • The needle will go flying when you cut it, so direct it away from your face and other precious objects.
  9. How to Repair A Broken Hip In A Plastic Doll: passo 9, imagem 1 %32
    • Optional: remove any excess burnt plastic from the ball joint.
  10. How to Repair A Broken Hip In A Plastic Doll: passo 10, imagem 1 %32 How to Repair A Broken Hip In A Plastic Doll: passo 10, imagem 2 %32 How to Repair A Broken Hip In A Plastic Doll: passo 10, imagem 3 %32
    • Remove the pin from the hip and apply super glue to the end.
    • Insert the pin back into the hole.
    • When you reinsert the pin, some glue may come out. Leave it for Step 11.
  11. How to Repair A Broken Hip In A Plastic Doll: passo 11, imagem 1 %32
    • Push the ball onto the pin. Press together for 1 minute to set the glue.
    • The glue will set in 1 minute but it will take 24 hours to fully cure.
  12. How to Repair A Broken Hip In A Plastic Doll: passo 12, imagem 1 %32
    • Apply glue around the seam for extra reinforcement.
  13. How to Repair A Broken Hip In A Plastic Doll: passo 13, imagem 1 %32 How to Repair A Broken Hip In A Plastic Doll: passo 13, imagem 2 %32
    • Now with the ball joint secured into the pelvis, carefully pop the leg back into the hip.
    • The doll's leg should now move as normal!
Conclusão
To reassemble your device, follow these instructions in order.
Lee Brunkhardt
Membro desde: 01/31/23
232 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-1, Andersen Winter 2023 Membro de UC Davis, Team 3-1, Andersen Winter 2023
UCD-ANDERSEN-W23S3G1
Membros da 5
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 30
Últimos 30 dias: 97
Duração total: 427
