Ir para o conteúdo principal
How to Remove the Front Panel in Your Whirlpool Refrigerator
O que você precisa
  1. How to Remove the Front Panel in Your Whirlpool Refrigerator, Safety precautions: passo 1, imagem 1 %32
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. How to Remove the Front Panel in Your Whirlpool Refrigerator, Open the doors: passo 2, imagem 1 %32 How to Remove the Front Panel in Your Whirlpool Refrigerator, Open the doors: passo 2, imagem 2 %32 How to Remove the Front Panel in Your Whirlpool Refrigerator, Open the doors: passo 2, imagem 3 %32
    • Depending on your repair, open one or both doors.
  3. How to Remove the Front Panel in Your Whirlpool Refrigerator, Unfasten the front panel: passo 3, imagem 1 %32 How to Remove the Front Panel in Your Whirlpool Refrigerator, Unfasten the front panel: passo 3, imagem 2 %32 How to Remove the Front Panel in Your Whirlpool Refrigerator, Unfasten the front panel: passo 3, imagem 3 %32
    • Remove the screw(s) securing the front panel.
  4. How to Remove the Front Panel in Your Whirlpool Refrigerator, Remove the front panel: passo 4, imagem 1 %32 How to Remove the Front Panel in Your Whirlpool Refrigerator, Remove the front panel: passo 4, imagem 2 %32 How to Remove the Front Panel in Your Whirlpool Refrigerator, Remove the front panel: passo 4, imagem 3 %32
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
Conclusão
Repair didn’t go as planned? Ask our Answers community for help.
Uma outra pessoa concluiu este guia.
nicO
Membro desde: 04/14/15
15.945 Reputação
Autoria de 89 guias
2Comentários do guia
Woah, felicidades tío!
Cayó un whirlpool hace unos meses en mis manos y li resolví gracias a ti.
Ahora tengo otro whirlpool ARC7470 y no enfría, bien...motor ok pero termostato muerto.
Es el n⁰ de pieza: Whirlpool C00312889
Pero no se cambiarlo. Saque el panel de temperatura pero no doy con donde esta y menos como lo puedo cambiar. #HELP.
GRACIAS!🙂
Omar Marí - Responder
Hola, tengo un refri Whirlpool, pero al abrir la puerta se apaga el panel, y deja de funcionar
Dieris Mora - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 31
Últimos 30 dias: 141
Ao todo: 6,343
