Introdução
Rusty bike chains are an issue, as they can weaken and suddenly snap during use. This guide will show how to clean your chain.
Here, we show a Raleigh Detour bike, but the steps will apply to almost any mutli-speed bike.
O que você precisa
Align a chain tool with one of the pins on the chain as shown.
Twist the handle of the chain tool in the clockwise direction to push the driving pin (of the chain tool) into the pin on the chain. This will begin to push the chain pin out.
Separate the two links that were joined by that pin once the chain pin is pushed out of the inner link (but not out of the outer link).
Pull the chain completely off of the chain rings.
Loop the chain around the top of one of the chain rings on the rear wheel of the bike.
Take the end of the chain on the rear side of the chain ring and lower it toward the derailleur.
Wind the chain in a clockwise direction around the first derailleur pulley as shown.
Wind the chain counterclockwise around the second derailleur pulley so it exits the derailleur going toward the front of the bike.
Flip the bike over so you can move the rear wheel (and thus the chain) freely.
Apply lube to the chain while using a rag to catch any excess lube. Be sure to turn the pedal cranks to move the chain as you pour the lube. This will make sure that the chain is fully lubricated.
Wipe off any excess lube with the rag.
