Ir para o conteúdo principal
How to Remove a Label From a Glass Jar
O que você precisa
  1. How to Remove a Label From a Glass Jar, How to Remove a Label From a Glass Jar: passo 1, imagem 1 %32
    • Boil enough water to fill both glass jars.
    • Pour the boiling water into the smaller jar using a tea kettle.
    • The hot water will heat up the glass and melt the adhesive from the inside.
  2. How to Remove a Label From a Glass Jar: passo 2, imagem 1 %32 How to Remove a Label From a Glass Jar: passo 2, imagem 2 %32
    • Place the lid onto the jar and tighten.
    • This step is optional if the larger container in Step 3 has a lid.
  3. How to Remove a Label From a Glass Jar: passo 3, imagem 1 %32 How to Remove a Label From a Glass Jar: passo 3, imagem 2 %32
    • Place the jar into a larger glass container.
  4. How to Remove a Label From a Glass Jar: passo 4, imagem 1 %32
    • Pour hot water into the larger jar until the water level is above the label.
  5. How to Remove a Label From a Glass Jar: passo 5, imagem 1 %32
    • Add a few drops of dish soap into the larger jar.
    • This helps to clean up residue from the label.
  6. How to Remove a Label From a Glass Jar: passo 6, imagem 1 %32 How to Remove a Label From a Glass Jar: passo 6, imagem 2 %32
    • Place the lid on the larger container and tighten.
    • This prevents heat from leaving the container.
    • Let the container sit for 10 to 15 minutes or until completely cooled.
  7. How to Remove a Label From a Glass Jar: passo 7, imagem 1 %32 How to Remove a Label From a Glass Jar: passo 7, imagem 2 %32
    • Remove the smaller jar from the larger container.
    • Pour the water out of the jar.
    • Peel the label off of the jar.
    • For containers with loose labels, the label will fall off or be able to be slipped off.
    • Wipe off excess residue with a cloth or paper towel.
Linha de Chegada
3 outras pessoas executaram este guia.
Ridhwan Hasnat
Membro desde: 01/17/22
235 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
Génial ! Je n'y avais jamais pensé. Merci beaucoup !
Josette Léost - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 824
