Ir para o conteúdo principal
How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation)
O que você precisa
  1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 1, imagem 1 %32 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 1, imagem 2 %32
    • On the top of the printer, turn the injector counter-clockwise and pull the tab.
  2. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 2, imagem 1 %32 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 2, imagem 2 %32 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 2, imagem 3 %32
    • Insert your fingers in the center of the filament cartridge and slowly pull it away from the printer.
  3. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 3, imagem 1 %32
    • Place the cartridge face up and pry off the lid of the cartridge.
  4. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 4, imagem 1 %32 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 4, imagem 2 %32
    • Gently flip the cartridge on its front and remove the two 2mm Hex screws using a Hex key.
  5. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 5, imagem 1 %32
    • Flip the cartridge face up and remove the gearbox and extractor tube.
  6. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 6, imagem 1 %32 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 6, imagem 2 %32 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 6, imagem 3 %32
    • Place your thumb on the front of the injector head and your middle finger on the needle.
    • Firmly pull the needle towards your thumb until the injector head cases cracks and pulls apart the case.
  7. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 7, imagem 1 %32 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 7, imagem 2 %32
    • Heat the needle using a lighter, making sure that the flame does not touch the needle.
    • Using needle-nose pliers, pull the needle from the tube.
    • Do not touch the needle as it may still be hot.
  8. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): passo 8, imagem 1 %32
    • Insert a paper clip and turn until the clog is removed.
Conclusão
Hector Vazquez
Membro desde: 10/23/20
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 533
