Ir para o conteúdo principal
How to Remove a Deodorant Stain From a Shirt
O que você precisa
  1. How to Remove a Deodorant Stain From a Shirt, How to Remove a Deodorant Stain From a Shirt: passo 1, imagem 1 %32 How to Remove a Deodorant Stain From a Shirt, How to Remove a Deodorant Stain From a Shirt: passo 1, imagem 2 %32 How to Remove a Deodorant Stain From a Shirt, How to Remove a Deodorant Stain From a Shirt: passo 1, imagem 3 %32
    • Measure two cups of water.
    • Pour the water into a bowl large enough to soak the garment.
  2. How to Remove a Deodorant Stain From a Shirt: passo 2, imagem 1 %32 How to Remove a Deodorant Stain From a Shirt: passo 2, imagem 2 %32
    • Measure 1 cup of white vinegar.
    • Pour the white vinegar into the same bowl with the cup of water.
  3. How to Remove a Deodorant Stain From a Shirt: passo 3, imagem 1 %32 How to Remove a Deodorant Stain From a Shirt: passo 3, imagem 2 %32
    • Soak the garment with the stain in the bowl for 30 minutes.
  4. How to Remove a Deodorant Stain From a Shirt: passo 4, imagem 1 %32 How to Remove a Deodorant Stain From a Shirt: passo 4, imagem 2 %32 How to Remove a Deodorant Stain From a Shirt: passo 4, imagem 3 %32
    • Measure and mix the following ingredients into a small bowl:
    • Half a cup of baking soda.
    • A tablespoon of salt.
    • A tablespoon of hydrogen peroxide.
  5. How to Remove a Deodorant Stain From a Shirt: passo 5, imagem 1 %32
    • Mix the baking soda, salt, and peroxide combination with a small utensil until the ingredients have been thoroughly combined.
    • The result should be a somewhat gritty paste.
  6. How to Remove a Deodorant Stain From a Shirt: passo 6, imagem 1 %32
    • Wring out the shirt and apply the paste to the stain.
    • Be sure to knead the mixture into the fabric to ensure that all of the threads have been exposed.
    • Leave the shirt idle for 20 minutes.
  7. How to Remove a Deodorant Stain From a Shirt: passo 7, imagem 1 %32
    • Wash off the excess paste.
    • Wash the garment in a normal wash cycle.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 29
Ao todo: 977
