Introdução
This guide will show you how to extract a screw that has broken while being embedded inside its hole, along with showing you how to replace it with a new one. This process works for screws inside walls, pieces of lumber, or metal. The guide requires a couple of power tools, so you should always use the necessary precautions when using them to avoid any injuries.
O que você precisa
Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
3 outras pessoas executaram este guia.
