Ir para o conteúdo principal
How to Remove Wax From Clothing
O que você precisa
  1. How to Remove Wax From Clothing, Removing Dried Wax: passo 1, imagem 1 %32
    • Set up the ironing board.
    • Plug in the iron and turn it on.
    • Your iron may need some time to heat up, especially if it is an older model.
  2. How to Remove Wax From Clothing: passo 2, imagem 1 %32
    • Place your piece of clothing onto the ironing board.
  3. How to Remove Wax From Clothing: passo 3, imagem 1 %32 How to Remove Wax From Clothing: passo 3, imagem 2 %32
    • Take your brown paper bag and fold it over the affected area, being sure to cover both sides of the waxy clothing.
  4. How to Remove Wax From Clothing: passo 4, imagem 1 %32
    • Press the iron on top of the brown paper bag.
    • Move the iron around as if you are ironing wrinkles out.
    • Be careful not to burn your fingers.
  5. How to Remove Wax From Clothing: passo 5, imagem 1 %32 How to Remove Wax From Clothing: passo 5, imagem 2 %32
    • Lift up the brown paper bag once it looks like the oil has saturated the bag.
    • Repeat steps 3-5 with new bags, until the remainder of the wax is soaked up.
  6. How to Remove Wax From Clothing: passo 6, imagem 1 %32
    • Feel free to wash your item now that the wax is removed, just as you normally would.
Conclusão
To finish getting wax out it is not a bad idea to wash your item, if possible, in a washing machine for a clothing item or use carpet wash for the carpet.
Molly Green
Membro desde: 04/23/20
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 30
Ao todo: 800
