Ir para o conteúdo principal
How to Remove Tarnish from a Pandora Bracelet
O que você precisa
  1. How to Remove Tarnish from a Pandora Bracelet, How to Remove Tarnish from a Pandora Bracelet: passo 1, imagem 1 %32 How to Remove Tarnish from a Pandora Bracelet, How to Remove Tarnish from a Pandora Bracelet: passo 1, imagem 2 %32 How to Remove Tarnish from a Pandora Bracelet, How to Remove Tarnish from a Pandora Bracelet: passo 1, imagem 3 %32
    • Take your bracelet and find the barrel clasp at the bottom.
    • Remove any charms on your bracelet and place them separately (they can also be cleaned if applicable).
  2. How to Remove Tarnish from a Pandora Bracelet: passo 2, imagem 1 %32
    • Grab any small bowl and place a medium sized sheet of aluminum foil over it.
    • Place your bracelet into the aluminum-covered bowl.
  3. How to Remove Tarnish from a Pandora Bracelet: passo 3, imagem 1 %32 How to Remove Tarnish from a Pandora Bracelet: passo 3, imagem 2 %32
    • Heat 1 cup of water in the microwave for 2 minutes.
    • Add that cup of hot water to your aluminum covered bowl.
    • Water can be superheated in the microwave. Be sure to stay within the recommended time limit.
  4. How to Remove Tarnish from a Pandora Bracelet: passo 4, imagem 1 %32 How to Remove Tarnish from a Pandora Bracelet: passo 4, imagem 2 %32
    • Add ¼ teaspoon of baking soda into your bowl with the hot water and bracelet.
    • Mix the baking soda until it is dissolved into your bowl completely.
  5. How to Remove Tarnish from a Pandora Bracelet: passo 5, imagem 1 %32
    • Let your bracelet sit in the baking soda for 3 minutes.
  6. How to Remove Tarnish from a Pandora Bracelet: passo 6, imagem 1 %32
    • After 3 minutes, scrub your bracelet entirely with a small scrub brush.
  7. How to Remove Tarnish from a Pandora Bracelet: passo 7, imagem 1 %32 How to Remove Tarnish from a Pandora Bracelet: passo 7, imagem 2 %32
    • After scrubbing, grab a towel and dry the bracelet entirely.
    • Make sure to dry the inside of the barrel clasp to prevent future tarnish build up.
  8. How to Remove Tarnish from a Pandora Bracelet: passo 8, imagem 1 %32
    • The bracelet is now free of tarnish!
Linha de Chegada
Michelle Ambriz
Membro desde: 02/19/24
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 9
Últimos 30 dias: 31
Duração total: 89
