Ir para o conteúdo principal
How to Remove Scratches from a Car's Interior
O que você precisa
  1. How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: passo 1, imagem 1 %32 How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: passo 1, imagem 2 %32
    • Clean the area around the scratch with the interior cleaner.
    • By removing the dirt, you will keep the debris from melting into the plastic and it will result in a smooth finish.
  2. How to Remove Scratches from a Car's Interior: passo 2, imagem 1 %32 How to Remove Scratches from a Car's Interior: passo 2, imagem 2 %32
    • Using the heat gun, gently apply heat to the plastic until it begins to soften.
    • Don't leave it on too long or else the plastic will burn and warp.
    • The plastic is ready for molding when it loses its texture and becomes slightly glossy.
  3. How to Remove Scratches from a Car's Interior: passo 3, imagem 1 %32
    • Apply the grain pad to the intended area using light pressure.
    • This should smooth out the scratch and will give a textured finish that will blend in with the rest of the panel.
    • Make sure you use a grain pad that closely resembles the trim of your car.
  4. How to Remove Scratches from a Car's Interior: passo 4, imagem 1 %32
    • Let the area cool and harden.
    • The texture should now look similar to the unaffected area.
  5. How to Remove Scratches from a Car's Interior: passo 5, imagem 1 %32
    • Use a super- fine grain sandpaper to sand out the area, making it smooth and authentic looking.
  6. How to Remove Scratches from a Car's Interior: passo 6, imagem 1 %32
    • Clean and dry the area again using the same method as in step 1 (the interior cleaner) and you're done!
Conclusão
By following these steps you will be able to remove scratches from your cars interior.
2 comentários
what brand of grain pads do you recommend? having a difficult time finding them onlinw
Ron Beyer - Responder
Any luck finding “grain texture” pads?
ChrisB - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 116
Últimos 7 dias: 1,376
Últimos 30 dias: 4,527
Duração total: 78,733
