Ir para o conteúdo principal
How to Remove Scratches from a Car's Interior
O que você precisa
  1. How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: passo 1, imagem 1 %32 How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: passo 1, imagem 2 %32
    • Clean the area around the scratch with the interior cleaner.
    • By removing the dirt, you will keep the debris from melting into the plastic and it will result in a smooth finish.
  2. How to Remove Scratches from a Car's Interior: passo 2, imagem 1 %32 How to Remove Scratches from a Car's Interior: passo 2, imagem 2 %32
    • Using the heat gun, gently apply heat to the plastic until it begins to soften.
    • Don't leave it on too long or else the plastic will burn and warp.
    • The plastic is ready for molding when it loses its texture and becomes slightly glossy.
  3. How to Remove Scratches from a Car's Interior: passo 3, imagem 1 %32
    • Apply the grain pad to the intended area using light pressure.
    • This should smooth out the scratch and will give a textured finish that will blend in with the rest of the panel.
    • Make sure you use a grain pad that closely resembles the trim of your car.
  4. How to Remove Scratches from a Car's Interior: passo 4, imagem 1 %32
    • Let the area cool and harden.
    • The texture should now look similar to the unaffected area.
  5. How to Remove Scratches from a Car's Interior: passo 5, imagem 1 %32
    • Use a super- fine grain sandpaper to sand out the area, making it smooth and authentic looking.
  6. How to Remove Scratches from a Car's Interior: passo 6, imagem 1 %32
    • Clean and dry the area again using the same method as in step 1 (the interior cleaner) and you're done!
Conclusão
By following these steps you will be able to remove scratches from your cars interior.
4Comentários do guia
what brand of grain pads do you recommend? having a difficult time finding them onlinw
Ron Beyer - Responder
Any luck finding “grain texture” pads?
ChrisB - Responder
i cant find any Grain pads / stamps online
Flow_Fire - Responder
have someone tried this trick and made it work?
Munir Ahmed - Responder
Comentar
Visualizações:
Últimas 24 horas: 60
Últimos 7 dias: 319
Últimos 30 dias: 1,447
Ao todo: 129,750
