Ir para o conteúdo principal
How to Remove Scratches from Your Car
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. How to Remove Scratches from Your Car, How to Remove Scratches from Your Car: passo 1, imagem 1 %32
    • Shoe polish can be used to visualize the scratches. Rub a small amount of dark shoe polish over the scratch.
  2. How to Remove Scratches from Your Car: passo 2, imagem 1 %32
    • Wipe the shoe polish over the panel. This fills the scratches with polish.
  3. How to Remove Scratches from Your Car: passo 3, imagem 1 %32
    • Block sand the panel with 2000-grit wet/dry sandpaper and plenty of water. Sand until the shoe polish disappears.
  4. How to Remove Scratches from Your Car: passo 4, imagem 1 %32
    • Polish out the sanding scratches with rubbing compound.
  5. How to Remove Scratches from Your Car: passo 5, imagem 1 %32
    • A polishing wheel makes short work of bringing the shine back. An oscillating polisher is less aggressive than this rotary polisher.
    • Don't buff through the paint into the next layer, especially on high-crown or sharp edges.
  6. How to Remove Scratches from Your Car: passo 6, imagem 1 %32
    • Finish with light hand buffing to remove the last of the compound. Follow with car wax.
Linha de Chegada
18 outras pessoas executaram este guia.
Brian Sallee
Membro desde: 03/07/12
1.793 Reputação
Autoria de 1 guia
3 comentários
Don’t you need to put the clear coat on the paint before waxing?
Richard E Riman - Responder
I like the blog; the content is very informative, i recommend others to read this content. Everyone love to buy cars; but when it get old or some of the parts of the car is damaged due to any reason. then it hurt to the honor of the car. and he/she want to replace the damaged part or the old car. As i live in brisbane and services of car wreckers in brisbane is very good. its better to fix your old car if your budged is not enough i think. just did some research in your area then you will find the best dealer for your car; who can make your car new again by just replacing the old parts of your car and paint your car again. thank you
Elex Rathore - Responder
mobile car wash
We are dedicated to providing quality DOORSTEP CAR WASH service, customer satisfaction is the top priority at a great value ALL OVER Destin, FL offering convenient hours. Our goal is to provide our customers with the friendliest, most convenient DOORSTEP CAR WASH experience possible. A CLEAN CAR & YOUR HAPPINESS is our top priority. If you’re not satisfied with your service, we’ll do everything we can to fix it. CALL US or MESSAGE US any time — we’re here with our service!
22 a - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 10,872
