Ir para o conteúdo principal
How to Remove Rust on Car Body
O que você precisa
    1. How to Remove Rust on Car Body, How to Remove Rust on Car Body: passo 1, imagem 1 %32 How to Remove Rust on Car Body, How to Remove Rust on Car Body: passo 1, imagem 2 %32
      • Spray down the rust with a spray bottle mixed with water and dish soap.
      • Wipe the mixture with a microfiber cloth.
      Pergunte ao FixBot
      Comentar
    2. How to Remove Rust on Car Body: passo 2, imagem 1 %32 How to Remove Rust on Car Body: passo 2, imagem 2 %32 How to Remove Rust on Car Body: passo 2, imagem 3 %32
      • Pour a small amount of rubbing alcohol onto a microfiber cloth.
      • Clean the rusted area with the cloth to remove any contaminants.
      Pergunte ao FixBot
      Comentar
    3. How to Remove Rust on Car Body: passo 3, imagem 1 %32 How to Remove Rust on Car Body: passo 3, imagem 2 %32 How to Remove Rust on Car Body: passo 3, imagem 3 %32
      • Rub the rusted area with 80-grit sandpaper until you start seeing the bare metal.
      Pergunte ao FixBot
      Comentar
    4. How to Remove Rust on Car Body: passo 4, imagem 1 %32 How to Remove Rust on Car Body: passo 4, imagem 2 %32
      • Rub the rusted area with 220-grit sandpaper until all of the rust is removed.
      • Dampen a cloth with soapy water and wipe down the sanded area.
      Pergunte ao FixBot
      Comentar
    5. How to Remove Rust on Car Body: passo 5, imagem 1 %32 How to Remove Rust on Car Body: passo 5, imagem 2 %32
      • This step is to prepare your spot for spray painting.
      • Add some paper around the areas you do not want paint on. Make sure you go a little past where you are going to spray paint to blend the paint into the surrounding area.
      Pergunte ao FixBot
      Comentar
    6. How to Remove Rust on Car Body: passo 6, imagem 1 %32 How to Remove Rust on Car Body: passo 6, imagem 2 %32 How to Remove Rust on Car Body: passo 6, imagem 3 %32
      • Spray three even coats of primer, waiting at least five minutes between each coat.
      • Let the third coat sit for 15 minutes.
      Pergunte ao FixBot
      Comentar
    7. How to Remove Rust on Car Body: passo 7, imagem 1 %32 How to Remove Rust on Car Body: passo 7, imagem 2 %32 How to Remove Rust on Car Body: passo 7, imagem 3 %32
      • Spray three even coats of paint on top of the primer, waiting five minutes between each coat.
      • You can either use a color similar to your car or you can get the actual color of you car by looking for the car's color code.
      • After the final coat, wait 24 hours before removing the surrounding paper.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
3 outras pessoas executaram este guia.
Robert Gutierrez
Membro desde: 08/25/22
199 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
Good guide, also recommending ChrisFix's video relating to this: https://www.youtube.com/watch?v=n4vusY2-...
Fixing Person - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 40
Últimos 30 dias: 165
Ao todo: 4,724
