Ir para o conteúdo principal
How to Remove Rust from the Nipper D-108
O que você precisa
  1. How to Remove Rust from the Nipper D-108, How to Remove Rust from the Nipper D-108: passo 1, imagem 1 %32 How to Remove Rust from the Nipper D-108, How to Remove Rust from the Nipper D-108: passo 1, imagem 2 %32 How to Remove Rust from the Nipper D-108, How to Remove Rust from the Nipper D-108: passo 1, imagem 3 %32
    • Take out a medium bowl.
    • Put on a pair of nitrile gloves.
  2. How to Remove Rust from the Nipper D-108: passo 2, imagem 1 %32 How to Remove Rust from the Nipper D-108: passo 2, imagem 2 %32 How to Remove Rust from the Nipper D-108: passo 2, imagem 3 %32
    • Pour about 3-4 tablespoons of baking soda into the bowl.
    • Pour enough white vinegar into the bowl to cover the nipper.
    • Mix baking soda and white vinegar together.
  3. How to Remove Rust from the Nipper D-108: passo 3, imagem 1 %32 How to Remove Rust from the Nipper D-108: passo 3, imagem 2 %32
    • Put the nipper in the mixture and soak for about an hour.
  4. How to Remove Rust from the Nipper D-108: passo 4, imagem 1 %32 How to Remove Rust from the Nipper D-108: passo 4, imagem 2 %32 How to Remove Rust from the Nipper D-108: passo 4, imagem 3 %32
    • Take a toothbrush and dip it in the mixture of vinegar and baking soda.
    • Scrub the rusty areas of the nipper until it is clean.
  5. How to Remove Rust from the Nipper D-108: passo 5, imagem 1 %32
    • Wash the nipper with water.
  6. How to Remove Rust from the Nipper D-108: passo 6, imagem 1 %32
    • Use a towel to wipe the nipper dry.
Conclusão
Vi Phan
Membro desde: 07/03/22
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 56
Duração total: 898
