Ir para o conteúdo principal
How to Remove Makeup Stain from Shirt
O que você precisa
  1. How to Remove Makeup Stain from Shirt, How to Remove Makeup Stain from Shirt: passo 1, imagem 1 %32
    • Place a white napkin or rag under the shirt to avoid making a mess or colour transfer into the garment.
  2. How to Remove Makeup Stain from Shirt: passo 2, imagem 1 %32 How to Remove Makeup Stain from Shirt: passo 2, imagem 2 %32
    • Pour micellar water over the stain
    • Micellar water can be replaced by any kind of water-based makeup remover.
    • Do not use an oil-based makeup remover as it will permanently damage the shirt.
  3. How to Remove Makeup Stain from Shirt: passo 3, imagem 1 %32 How to Remove Makeup Stain from Shirt: passo 3, imagem 2 %32
    • Pat the stain dry with the napkin/rag from Step 1.
    • Do not use Kleenex tissues as they will fall apart and make a mess by sticking to the fabric.
  4. How to Remove Makeup Stain from Shirt: passo 4, imagem 1 %32
    • Wash the shirt in cold water with the detergent of your choice.
  5. How to Remove Makeup Stain from Shirt: passo 5, imagem 1 %32
    • Pour detergent over the stain. Pour baking soda or powder over the soap.
    • The recommended measurement is 1/4 of a teaspoon of baking soda/powder but you may use more if the stain is larger.
  6. How to Remove Makeup Stain from Shirt: passo 6, imagem 1 %32
    • Scrub the paste into the shirt with a toothbrush.
  7. How to Remove Makeup Stain from Shirt: passo 7, imagem 1 %32
    • Let rest for 15 minutes.
  8. How to Remove Makeup Stain from Shirt: passo 8, imagem 1 %32
    • Wash the shirt in cold water followed by lukewarm water.
  9. How to Remove Makeup Stain from Shirt: passo 9, imagem 1 %32
    • Let the shirt air dry and iron it if necessary.
Conclusão
Let the shirt air dry and iron as needed.
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 26
Ao todo: 514
