Ir para o conteúdo principal
How to Remove Crinkles in a Jump Rope
O que você precisa
  1. How to Remove Crinkles in a Jump Rope, How to Remove Crinkles in a Jump Rope: passo 1, imagem 1 %32 How to Remove Crinkles in a Jump Rope, How to Remove Crinkles in a Jump Rope: passo 1, imagem 2 %32
    • Clean the jump rope if it’s dirty or used, and remove the handles.
  2. How to Remove Crinkles in a Jump Rope: passo 2, imagem 1 %32 How to Remove Crinkles in a Jump Rope: passo 2, imagem 2 %32 How to Remove Crinkles in a Jump Rope: passo 2, imagem 3 %32
    • Fill 3/4 of a large pot with water.
  3. How to Remove Crinkles in a Jump Rope: passo 3, imagem 1 %32
    • Set the pot on a stove and let it reach boiling temperature.
    • Caution: Be careful when handling boiling water since it can cause burns when handled incorrectly. Have an adult help you if needed.
  4. How to Remove Crinkles in a Jump Rope: passo 4, imagem 1 %32 How to Remove Crinkles in a Jump Rope: passo 4, imagem 2 %32 How to Remove Crinkles in a Jump Rope: passo 4, imagem 3 %32
    • Place a large bucket outside.
    • Place the crinkled jump rope into the bucket.
  5. How to Remove Crinkles in a Jump Rope: passo 5, imagem 1 %32 How to Remove Crinkles in a Jump Rope: passo 5, imagem 2 %32
    • Carefully pour the boiling water into the bucket.
    • Caution: Boiling water can cause burns, so please handle with care.
  6. How to Remove Crinkles in a Jump Rope: passo 6, imagem 1 %32 How to Remove Crinkles in a Jump Rope: passo 6, imagem 2 %32
    • Let the jump rope sit with the boiled water in the bucket for about 3 to 5 minutes.
    • Remove the jump rope with a pair of tongs and place them on the ground.
    • Let the jump rope cool down enough to handle but be sure that it is still warm.
  7. How to Remove Crinkles in a Jump Rope: passo 7, imagem 1 %32 How to Remove Crinkles in a Jump Rope: passo 7, imagem 2 %32 How to Remove Crinkles in a Jump Rope: passo 7, imagem 3 %32
    • Find a circular object to wrap the jump rope around and slowly apply force to pull and hold it for about 2 minutes.
    • Your jump rope should now be free of crinkles and be ready to use.
    • If you still have some crinkles in the jump rope, feel free to stack weights on top of it and let it sit overnight, or follow the guide over again to get a more refined rope.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 58
Duração total: 744
