Ir para o conteúdo principal
How to Reinforce the Base of a Torn Backpack
O que você precisa
  1. How to Reinforce the Base of a Torn Backpack, Backpack Base: passo 1, imagem 1 %32
    • Pull out any excess thread that is left over from the tear.
    • Make sure to be careful in pulling the thread to avoid causing excess damage.
  2. How to Reinforce the Base of a Torn Backpack: passo 2, imagem 1 %32
    • Turn the backpack inside out.
    • Carefully do this to not make the hole bigger.
  3. How to Reinforce the Base of a Torn Backpack: passo 3, imagem 1 %32 How to Reinforce the Base of a Torn Backpack: passo 3, imagem 2 %32
    • Pin the hole together using sewing pins.
    • Gently pin to avoid poking or hurting yourself with the pins.
  4. How to Reinforce the Base of a Torn Backpack: passo 4, imagem 1 %32 How to Reinforce the Base of a Torn Backpack: passo 4, imagem 2 %32
    • Thread your needle with a similar color thread to your backpack.
    • Tie a knot at the end of the thread.
  5. How to Reinforce the Base of a Torn Backpack: passo 5, imagem 1 %32 How to Reinforce the Base of a Torn Backpack: passo 5, imagem 2 %32 How to Reinforce the Base of a Torn Backpack: passo 5, imagem 3 %32
    • Sew the hole shut, removing pins as you go.
    • Use this Basic Sewing guide for exact stitching.
    • Unpin carefully to avoid poking or hurting yourself with the pins
    • Tie a knot at the end to close off the stitch.
    • Cut any excess thread.
  6. How to Reinforce the Base of a Torn Backpack: passo 6, imagem 1 %32 How to Reinforce the Base of a Torn Backpack: passo 6, imagem 2 %32 How to Reinforce the Base of a Torn Backpack: passo 6, imagem 3 %32
    • Trace an additional piece of lining with ¼” seam allowance in the shape of the backpack bottom.
    • Cut the fabric for the lining.
    • Pin the fabric around the perimeter to the base of the backpack.
  7. How to Reinforce the Base of a Torn Backpack: passo 7, imagem 1 %32
    • Sew the lining to the base of the inside out backpack using the same process in Step 5.
    • Use this Basic Sewing tutorial as needed.
    • Gently sew and unpin to avoid hurting yourself with the pins.
  8. How to Reinforce the Base of a Torn Backpack: passo 8, imagem 1 %32
    • Enjoy your newly strengthened backpack!
Conclusão
Congratulations you have now reinforced and repaired your backpack! Good as new if not better.
Amber Irfan
Membro desde: 02/02/24
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-4, Andersen Winter 2024 Membro de UC Davis, Team 4-4, Andersen Winter 2024
UCD-ANDERSEN-W24S4G4
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 40
Duração total: 115
