Ir para o conteúdo principal
How to Refinish a Scratched Wood Table
O que você precisa
  1. How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: passo 1, imagem 1 %32 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: passo 1, imagem 2 %32 How to Refinish a Scratched Wood Table, How to Refinish a Scratched Wood Table: passo 1, imagem 3 %32
    • Flip your table over on the tabletop or on the side if applicable.
    • Get your hex keys or screwdriver.
    • Using your tool to unscrew all of the legs on the table.
  2. How to Refinish a Scratched Wood Table: passo 2, imagem 1 %32 How to Refinish a Scratched Wood Table: passo 2, imagem 2 %32
    • Using a damp cloth, wipe down the tabletop and all of the legs.
  3. How to Refinish a Scratched Wood Table: passo 3, imagem 1 %32 How to Refinish a Scratched Wood Table: passo 3, imagem 2 %32 How to Refinish a Scratched Wood Table: passo 3, imagem 3 %32
    • Get the 220 grit sandpaper and cut a smaller piece.
    • Sand the tabletop until all scratches are leveled with the wood.
    • Sand all of the legs.
    • You may use a sander if you do not want to sand the table by hand.
  4. How to Refinish a Scratched Wood Table: passo 4, imagem 1 %32
    • Paint all of the legs and let them dry.
    • Be sure to mix your paint to ensure it hasn't separated before applying.
  5. How to Refinish a Scratched Wood Table: passo 5, imagem 1 %32
    • Paint the tabletop and let it dry.
    • If using wood paint, coat the tabletop more than once.
  6. How to Refinish a Scratched Wood Table: passo 6, imagem 1 %32 How to Refinish a Scratched Wood Table: passo 6, imagem 2 %32 How to Refinish a Scratched Wood Table: passo 6, imagem 3 %32
    • Line up the legs with the screw holes.
    • Hand tighten the screws and then use the hex keys or screwdriver to completely tighten.
    • Attach all legs and flip the table onto its legs.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Gurvir Boparai
Membro desde: 01/10/22
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 54
Ao todo: 1,734
