Ir para o conteúdo principal
How to Reattach the Head of a Mailbox to the Base
O que você precisa
  1. How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: passo 1, imagem 1 %32 How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: passo 1, imagem 2 %32
    • Inspect the head of the mailbox to see where the detachment is located.
  2. How to Reattach the Head of a Mailbox to the Base: passo 2, imagem 1 %32 How to Reattach the Head of a Mailbox to the Base: passo 2, imagem 2 %32
    • Gather all materials needed.
    • Adhesive can be included depending on the tight fit you desire.
  3. How to Reattach the Head of a Mailbox to the Base: passo 3, imagem 1 %32 How to Reattach the Head of a Mailbox to the Base: passo 3, imagem 2 %32 How to Reattach the Head of a Mailbox to the Base: passo 3, imagem 3 %32
    • Measure out the wood plank to match the length and width of the mailbox head.
  4. How to Reattach the Head of a Mailbox to the Base: passo 4, imagem 1 %32 How to Reattach the Head of a Mailbox to the Base: passo 4, imagem 2 %32 How to Reattach the Head of a Mailbox to the Base: passo 4, imagem 3 %32
    • Use a hammer or mallet to nail this wood plank to the bottom of mailbox head. Use at least four nails for this task.
    • Use gloves, if deemed necessary!
  5. How to Reattach the Head of a Mailbox to the Base: passo 5, imagem 1 %32 How to Reattach the Head of a Mailbox to the Base: passo 5, imagem 2 %32
    • Screw the sides down for a stronger fit using at least four screws.
  6. How to Reattach the Head of a Mailbox to the Base: passo 6, imagem 1 %32
    • Align the mailbox head back on the post.
  7. How to Reattach the Head of a Mailbox to the Base: passo 7, imagem 1 %32 How to Reattach the Head of a Mailbox to the Base: passo 7, imagem 2 %32
    • Hammer down the head to the post of the mailbox with at least three more nails.
    • Add adhesive if necessary for a sturdier attachment.
    • Since your hands are inside the mailbox, it may be best to use gloves for this task.
Linha de Chegada
Terrell Cobbins
Membro desde: 03/21/23
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 183
