Ir para o conteúdo principal
How to Reattach a Cabinet's Center Stile
O que você precisa
  1. How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: passo 1, imagem 1 %32 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: passo 1, imagem 2 %32 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: passo 1, imagem 3 %32
    • Measure the width and length of the detached center stile.
  2. How to Reattach a Cabinet's Center Stile: passo 2, imagem 1 %32 How to Reattach a Cabinet's Center Stile: passo 2, imagem 2 %32 How to Reattach a Cabinet's Center Stile: passo 2, imagem 3 %32
    • Mark the measurements on the wood block that will be the supporting piece.
    • You may need to extend the length of the new stile to cover several inches above and below the stile's point of attachment.
    • Follow the markings and use the hacksaw to cut down the wood block so that it is the same width as the center stile.
  3. How to Reattach a Cabinet's Center Stile: passo 3, imagem 1 %32 How to Reattach a Cabinet's Center Stile: passo 3, imagem 2 %32 How to Reattach a Cabinet's Center Stile: passo 3, imagem 3 %32
    • Apply a generous amount of wood glue to one side of the wood block.
    • Spread the glue to cover the entire side of the wood.
  4. How to Reattach a Cabinet's Center Stile: passo 4, imagem 1 %32 How to Reattach a Cabinet's Center Stile: passo 4, imagem 2 %32
    • Place the wood piece against the back of stile and cabinet frame.
    • Use clamps to hold the center stile, cabinet frame, and wood supporting piece together.
    • The clamps prevent the wood block from sliding off the center stile so that it will dry in a fixed position.
    • Remove the clamps after 24 hours.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 76
Duração total: 1,310
