Introdução
These instructions provide a simple technique for reattaching a broken piece of wood to any type of furniture. We demonstrate this technique on a nightstand, but it can be used on any wooden surface that needs to be fixed. No carpentry skill is required to complete this repair.
O que você precisa
Dust the surface of the fragment and the damaged area of the furniture.
Any household cleaner will work; we recommend a damp rag.
Continue using furniture as you had before!
3 outras pessoas executaram este guia.
3Comentários do guia
The clean and modern design of our products allows you to use the items for years. we are starting to sale small products and want to get your feedback for these products. We are not the World best online store but we want to be and this is only possible with your response and recommendation.
Very easy to follow instructions. I've found the most difficult part of any fence build is getting the posts lined up properly and getting them plumb. Even with a line, it can be tough . https://www.whitewooden.com/
