Ir para o conteúdo principal
How to Reattach a Broken Jhumki Style Earring
O que você precisa
  1. How to Reattach a Broken Jhumki Style Earring, How to Reattach a Broken Jhumki Style Earring: passo 1, imagem 1 %32
    • Use your hands or small chain nose pliers to twist open the Jhumki jump ring.
    • Rotate the jump ring to disconnect it from the Jhumki.
  2. How to Reattach a Broken Jhumki Style Earring: passo 2, imagem 1 %32
    • Take an open jump ring (4 mm) and gently twist it open.
    • The open jump ring should not be bigger than the earring back.
  3. How to Reattach a Broken Jhumki Style Earring: passo 3, imagem 1 %32 How to Reattach a Broken Jhumki Style Earring: passo 3, imagem 2 %32
    • Thread the open jump ring through the hoop of the earring.
    • Carefully twist the jump ring close.
  4. How to Reattach a Broken Jhumki Style Earring: passo 4, imagem 1 %32
    • Optional: Cut a small piece of tape.
    • Carefully flatten the tape on the opening of the open jump ring.
  5. How to Reattach a Broken Jhumki Style Earring: passo 5, imagem 1 %32
    • Thread the earring through the stud of the Jhumki.
  6. How to Reattach a Broken Jhumki Style Earring: passo 6, imagem 1 %32 How to Reattach a Broken Jhumki Style Earring: passo 6, imagem 2 %32 How to Reattach a Broken Jhumki Style Earring: passo 6, imagem 3 %32
    • Secure the Jhumki using the earring back.
Linha de Chegada
Sruthissree Raghukumar
Membro desde: 10/20/23
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 129
