Ir para o conteúdo principal
How to Properly Clean the Airox Legendair
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. How to Properly Clean the Airox Legendair, How to Properly Clean the Airox Legendair: passo 1, imagem 1 %32
    • First, switch off the device.
    • Place the device in a clean and open environment.
  2. How to Properly Clean the Airox Legendair: passo 3, imagem 1 %32
    • Using a cloth or a sponge slightly dampened with a bactericide or germicide solution, gently clean the outside of the device.
  3. How to Properly Clean the Airox Legendair: passo 4, imagem 1 %32
    • If necessary, spray the device lightly with the germicide solution, taking account of the requirements discussed in the preliminary operations.
    • Do not allow any liquid to enter inside the device (in particular through the cooling apertures).
    • Use a gentle air blast to clear away any remaining liquid from ventilator.
Conclusão
Make sure the ventilator is in good visual condition upon thorough cleaning of the machine.
Equipe
Cal Poly, Team S7-G15, Paton Spring 2020 Membro de Cal Poly, Team S7-G15, Paton Spring 2020
CPSU-PATON-S20S7G15
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 122
