Ir para o conteúdo principal
How to Propagate a Plant in Water
O que você precisa
  1. How to Propagate a Plant in Water, How to Propagate a Plant in Water: passo 1, imagem 1 %32 How to Propagate a Plant in Water, How to Propagate a Plant in Water: passo 1, imagem 2 %32
    • Using scissors or shears cut the plant below a node.
    • Node: a point where a leaf or branch emerges.
  2. How to Propagate a Plant in Water: passo 2, imagem 1 %32 How to Propagate a Plant in Water: passo 2, imagem 2 %32
    • Remove the bottom leaves and cut the plant diagonally.
    • Cutting the plant in a diagonal will increase surface area and allow for better water consumption.
  3. How to Propagate a Plant in Water: passo 3, imagem 1 %32 How to Propagate a Plant in Water: passo 3, imagem 2 %32
    • Optional: Coat the cutting in rooting powder.
    • Rooting powder will accelerate the rooting process and yield a higher success rate.
  4. How to Propagate a Plant in Water: passo 4, imagem 1 %32
    • Fill a glass cup with water.
  5. How to Propagate a Plant in Water: passo 5, imagem 1 %32
    • Place the cutting in the cup.
    • The cup should be in a well-ventilated area with bright indirect light.
    • Change the water every week to prevent bacterial growth.
  6. How to Propagate a Plant in Water: passo 6, imagem 1 %32 How to Propagate a Plant in Water: passo 6, imagem 2 %32
    • Once the roots are 1-2 inches long, transfer to medium (soil, lecca, etc.).
    • Water regularly to reduce shock.
Conclusão
You did it! Congratulations on successfully propagating your plant in water!
5 outras pessoas executaram este guia.
Daniela Perez
Membro desde: 02/21/24
235 Reputação
Autoria de 1 guia
Equipe
CSU Sacramento, Team 1-14, Laflen Spring 2024 Membro de CSU Sacramento, Team 1-14, Laflen Spring 2024
CSUSAC-LAFLEN-S24S1G14
2 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 20
Últimos 30 dias: 97
Ao todo: 1,677
