Ir para o conteúdo principal
How to Prevent a Run or Tear in Tights from Spreading
O que você precisa
  1. How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: passo 1, imagem 1 %32 How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: passo 1, imagem 2 %32
    • Put the ripped tights on for easier repair, or leave them on if you’re already wearing them.
    • Gather clear nail polish and a pair of scissors.
  2. How to Prevent a Run or Tear in Tights from Spreading: passo 2, imagem 1 %32
    • Locate all potential runs or directions that the rip can expand.
    • Runs will not usually expand horizontally, but be sure to check both vertical ends of the run.
  3. How to Prevent a Run or Tear in Tights from Spreading: passo 3, imagem 1 %32
    • Gently tug the tights away from your skin to prevent the nail polish from affixing to your body.
  4. How to Prevent a Run or Tear in Tights from Spreading: passo 4, imagem 1 %32 How to Prevent a Run or Tear in Tights from Spreading: passo 4, imagem 2 %32
    • Brush a dollop of clear nail polish on all potential runs.
    • Small runs will require just a dab of nail polish while larger holes may require a thin coat.
    • Repeat these steps to all potential runs and loose threads.
  5. How to Prevent a Run or Tear in Tights from Spreading: passo 5, imagem 1 %32
    • Once the nail polish has dried, you may cut any hanging pieces of thread.
    • The nail polish will take about 1 minute to dry.
    • Be sure to complete this step after applying the nail polish and letting it dry or a new run will form.
Conclusão
These steps can save a pair of tights from becoming too tattered for normal use.
Uma outra pessoa concluiu este guia.
Audrey Fremier
Membro desde: 02/23/15
191 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-1, Green Winter 2015 Membro de Cal Poly, Team 12-1, Green Winter 2015
CPSU-GREEN-W15S12G1
6 Membros
7 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 61
Últimos 30 dias: 319
Duração total: 37,024
