Ir para o conteúdo principal
How to Pick Up a Dropped Stitch in Knitting
O que você precisa
  1. How to Pick Up a Dropped Stitch in Knitting, How to Pick Up a Dropped Stitch in Knitting: passo 1, imagem 1 %32
    • Locate the dropped stitch.
    • A dropped stitch is a loop of unsecured yarn, which means that no yarn is going through the loop.
  2. How to Pick Up a Dropped Stitch in Knitting: passo 2, imagem 1 %32 How to Pick Up a Dropped Stitch in Knitting: passo 2, imagem 2 %32
    • Insert the left needle through the loop of the dropped stitch.
    • You may use the right needle to grab the dropped stitch, but the dropped stitch must end on the left needle.
  3. How to Pick Up a Dropped Stitch in Knitting: passo 3, imagem 1 %32
    • Locate the bar of yarn behind the dropped stitch.
    • Depending on how many rows the stitch has unraveled, there may be multiple bars of yarn. If the stitch has unraveled more than one row, locate the bottom bar.
  4. How to Pick Up a Dropped Stitch in Knitting: passo 4, imagem 1 %32 How to Pick Up a Dropped Stitch in Knitting: passo 4, imagem 2 %32
    • Insert the right needle beneath the bottom bar of yarn and lift it onto the left needle.
  5. How to Pick Up a Dropped Stitch in Knitting: passo 5, imagem 1 %32 How to Pick Up a Dropped Stitch in Knitting: passo 5, imagem 2 %32
    • Use the tight needle to slip the dropped stitch over the bar of yarn.
  6. How to Pick Up a Dropped Stitch in Knitting: passo 6, imagem 1 %32 How to Pick Up a Dropped Stitch in Knitting: passo 6, imagem 2 %32 How to Pick Up a Dropped Stitch in Knitting: passo 6, imagem 3 %32
    • Repeat steps 3-5 for each row that the dropped stitch has unraveled.
  7. How to Pick Up a Dropped Stitch in Knitting: passo 7, imagem 1 %32
    • Once the dropped stitch has been picked up all the way to the current row, proceed in pattern.
Conclusão
Your knitting project should now be fixed, and you can proceed with your work.
Uma outra pessoa concluiu este guia.
Jillian Garcia
Membro desde: 09/28/22
175 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 435
