Ir para o conteúdo principal
How to Perform a Hard Reset
O que você precisa
  1. How to Perform a Hard Reset, Face Plate: passo 1, imagem 1 %32
    • Press the eject button on the bottom left corner of the face plate.
  2. How to Perform a Hard Reset: passo 2, imagem 1 %32 How to Perform a Hard Reset: passo 2, imagem 2 %32 How to Perform a Hard Reset: passo 2, imagem 3 %32
    • Begin by slightly lifting the face plate out from the side located by the release button.
    • Slide towards the side of the eject button, then completely lift out.
  3. How to Perform a Hard Reset, How to Perform a Hard Reset: passo 3, imagem 1 %32
    • You will now have the face plate and the main component that includes the CD drive. Put the face plate aside and locate the small circle button labelled "Reset" on the main component.
    • Make sure the car power is on.
    • Press and hold the reset button with a pointed edge tool for 5 seconds.
Conclusão
10 outras pessoas executaram este guia.
Connor Finley
Membro desde: 02/18/17
857 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S2-G5, Lacy Spring 2017 Membro de USF Tampa, Team S2-G5, Lacy Spring 2017
USFT-LACY-S17S2G5
Membros da 4
Autoria de 11 guias
Um comentário
I have a Kenwood car stereo w4044ua and i put a code on it, will the code be removed when I reset ihe device
Defcon 1 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 100
Últimos 30 dias: 427
Duração total: 61,854
