Ir para o conteúdo principal
How to Patch a Tear in Vinyl Furniture
O que você precisa
  1. How to Patch a Tear in Vinyl Furniture, How to Patch a Tear in Vinyl Furniture: passo 1, imagem 1 %32
    • Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
  2. How to Patch a Tear in Vinyl Furniture: passo 2, imagem 1 %32
    • Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
  3. How to Patch a Tear in Vinyl Furniture: passo 3, imagem 1 %32 How to Patch a Tear in Vinyl Furniture: passo 3, imagem 2 %32
    • Use the spatula tool to insert the backing fabric underneath the tear.
  4. How to Patch a Tear in Vinyl Furniture: passo 4, imagem 1 %32 How to Patch a Tear in Vinyl Furniture: passo 4, imagem 2 %32
    • Use the spatula to apply the adhesive to the damaged area.
    • Choose a color that matches your furniture. You may need to mix colors to acheive the correct shade.
  5. How to Patch a Tear in Vinyl Furniture: passo 5, imagem 1 %32
    • Let the adhesive dry for approximately four hours.
    • You may use a hair dryer to speed up the drying process.
  6. How to Patch a Tear in Vinyl Furniture: passo 6, imagem 1 %32 How to Patch a Tear in Vinyl Furniture: passo 6, imagem 2 %32
    • Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
    • Apply light pressure to even out the edges.
Conclusão
Once the adhesive is dry, the furniture is ready for use!
4 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 55
Ao todo: 27,321
