Ir para o conteúdo principal
How to Patch a Hole in a Kote
O que você precisa
  1. How to Patch a Hole in a Kote, How to Patch a Hole in a Kote: passo 1, imagem 1 %32
    • Use the ruler to measure the hole, and add a 1/4 to 1/2 inch buffer on all sides.
  2. How to Patch a Hole in a Kote: passo 2, imagem 1 %32
    • Use the ruler and pen to create guiding lines for these measurements directly on the backside of the leather patch.
  3. How to Patch a Hole in a Kote: passo 3, imagem 1 %32
    • Use the scissors to cut along the guiding lines.
  4. How to Patch a Hole in a Kote: passo 4, imagem 1 %32
    • Center the leather patch over the hole and pin it in place.
  5. How to Patch a Hole in a Kote: passo 5, imagem 1 %32
    • Cut approximately 30 inches of thread and thread 15 inches through the needle.
    • Tie the two ends of the thread into a square knot by creating a loop, drawing the ends through the loop, and pulling it tight.
  6. How to Patch a Hole in a Kote: passo 6, imagem 1 %32 How to Patch a Hole in a Kote: passo 6, imagem 2 %32
    • After drawing the thread through the patch from below, about 1/4 inch from the edge, use the thimble to push the needle through the kote, just outside the patch.
    • Use the pliers to pull the needle through the kote and leather.
    • Repeat the process all around the patch until you return to the first stitch.
  7. How to Patch a Hole in a Kote: passo 7, imagem 1 %32 How to Patch a Hole in a Kote: passo 7, imagem 2 %32 How to Patch a Hole in a Kote: passo 7, imagem 3 %32
    • Knot the final stitch in place by running the needle under the first stitch.
    • Pull the thread to create a loop, and run the needle through the loop towards you.
    • To hide the knot, run the needle beneath the patch and pull the thread through, cutting it close to the patch.
  8. How to Patch a Hole in a Kote: passo 8, imagem 1 %32
    • You have successfully patched the hole in your kote.
Conclusão
To patch your kote, follow these steps in chronological order.
Dawn Lattin
Membro desde: 06/11/21
157 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 26
Duração total: 715
