Ir para o conteúdo principal
How to Patch a Burn Hole in a Fabric
O que você precisa
  1. How to Patch a Burn Hole in a Fabric, Identify the repair area: passo 1, imagem 1 %32 How to Patch a Burn Hole in a Fabric, Identify the repair area: passo 1, imagem 2 %32 How to Patch a Burn Hole in a Fabric, Identify the repair area: passo 1, imagem 3 %32
    • Locate the burn holes in the garment and gather the tools needed for the repair.
  2. How to Patch a Burn Hole in a Fabric, Prepare the patch: passo 2, imagem 1 %32 How to Patch a Burn Hole in a Fabric, Prepare the patch: passo 2, imagem 2 %32 How to Patch a Burn Hole in a Fabric, Prepare the patch: passo 2, imagem 3 %32
    • Lay your garment on a flat surface.
    • Draw a line around the bottle lid to use it as a guide.
    • Note: In this example, we chose the lid because it was at least 1cm larger than the hole on each side. For future patching, please keep this margin in mind.
  3. How to Patch a Burn Hole in a Fabric, Cut the patches: passo 3, imagem 1 %32 How to Patch a Burn Hole in a Fabric, Cut the patches: passo 3, imagem 2 %32 How to Patch a Burn Hole in a Fabric, Cut the patches: passo 3, imagem 3 %32
    • Use a pair of scissors to cut around the patches and set them aside.
  4. How to Patch a Burn Hole in a Fabric, Place the patch: passo 4, imagem 1 %32 How to Patch a Burn Hole in a Fabric, Place the patch: passo 4, imagem 2 %32 How to Patch a Burn Hole in a Fabric, Place the patch: passo 4, imagem 3 %32
    • Place the top edge of the patch carefully onto the item, and apply gentle pressure.
    • Use the backside of a spoon to apply harder pressure, and use a circular motion to press down around the patch for 1-2 minutes.
  5. How to Patch a Burn Hole in a Fabric, Patch additional holes: passo 5, imagem 1 %32 How to Patch a Burn Hole in a Fabric, Patch additional holes: passo 5, imagem 2 %32 How to Patch a Burn Hole in a Fabric, Patch additional holes: passo 5, imagem 3 %32
    • Look for additional burn holes and repeat the same steps shown before to patch them.
    • Note: Sometimes you will need to patch both the outside and inside part of a garment.
  6. How to Patch a Burn Hole in a Fabric, Finished and ready!: passo 6, imagem 1 %32 How to Patch a Burn Hole in a Fabric, Finished and ready!: passo 6, imagem 2 %32
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
Membro desde: 07/19/23
9.298 Reputação
Autoria de 62 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
Membros da 22
Autoria de 161 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 24
Duração total: 107
