Ir para o conteúdo principal
How to Open Logitech Harmony 1100
O que você precisa
  1. How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: passo 1, imagem 1 %32 How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: passo 1, imagem 2 %32
    • Remove battery cover, pushing down on circled areas and pushing outward
    • Remove battery by lifting up on corner exposed by indent in case
  2. How to Open Logitech Harmony 1100: passo 2, imagem 1 %32
    • Use a J0 screwdriver head
    • Remove 3 screws from battery compartment
  3. How to Open Logitech Harmony 1100: passo 3, imagem 1 %32 How to Open Logitech Harmony 1100: passo 3, imagem 2 %32
    • Open connector port on side
    • Remove screw with PH00 screwdriver head
  4. How to Open Logitech Harmony 1100: passo 4, imagem 1 %32 How to Open Logitech Harmony 1100: passo 4, imagem 2 %32 How to Open Logitech Harmony 1100: passo 4, imagem 3 %32
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • Also the plastic connector door will fall off. It will need to be put back upon reassembly.
Conclusão
Uma outra pessoa concluiu este guia.
Keegan Williams
Membro desde: 02/19/16
216 Reputação
Autoria de 2 guias
Equipe
Ohio State, Team 1-5, Garvin Spring 2016 Membro de Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
Membros da 3
Autoria de 3 guias
Um comentário
Will changing the battery reset the settings within the remote?
wiboman AT gmail DOT com
Wibo Lammerts - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 1,385
