Ir para o conteúdo principal
How to Mend a Hole in a Cotton Blanket
O que você precisa
  1. How to Mend a Hole in a Cotton Blanket, How to Mend a Hole in a Cotton Blanket: passo 1, imagem 1 %32
    • Find the hole in the blanket
  2. How to Mend a Hole in a Cotton Blanket: passo 2, imagem 1 %32
    • Put the needle through the blanket, right below the hole picking up just a little bit of the fabric and do not pull the thread all the way through.
  3. How to Mend a Hole in a Cotton Blanket: passo 3, imagem 1 %32 How to Mend a Hole in a Cotton Blanket: passo 3, imagem 2 %32
    • Repeat step 2 about 2 more times by inserting the needle through the same hole
  4. How to Mend a Hole in a Cotton Blanket: passo 4, imagem 1 %32
    • On the last you pull, do not pull all the way for it creates a loop. Put your needle through the loop, pull the thread all the way and this creates a secure knot.
  5. How to Mend a Hole in a Cotton Blanket: passo 5, imagem 1 %32 How to Mend a Hole in a Cotton Blanket: passo 5, imagem 2 %32 How to Mend a Hole in a Cotton Blanket: passo 5, imagem 3 %32
    • Pick one side of the hole and go through to the other side while picking up fabric from the other side and pull our thread through all the way.
  6. How to Mend a Hole in a Cotton Blanket: passo 6, imagem 1 %32
    • Repeat step 5 going in an upward direction until you have reached the top of the hole.
  7. How to Mend a Hole in a Cotton Blanket: passo 7, imagem 1 %32
    • The last thread you pull through, do not pull all the way but instead put your need through the loop it creates and create a secure knot. Repeat this step about 2-3 more times threading through the same hole to create an extra secure knot.
  8. How to Mend a Hole in a Cotton Blanket: passo 8, imagem 1 %32
    • Snip off the thread and make sure the hole has been mended. You can clean it up by trimming any loose fabric.
Linha de Chegada
Kiara Lee
Membro desde: 09/11/21
157 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 27
Últimos 30 dias: 154
Ao todo: 6,871
