Ir para o conteúdo principal
How to Manually Eject a Stuck Disc in a PlayStation 5
O que você precisa
  1. How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: passo 1, imagem 1 %32 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: passo 1, imagem 2 %32 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: passo 1, imagem 3 %32
    • Unplug all cables going into the console (power, ethernet, hdmi and etc).
    • This should be done for your safety and for the safety of the device.
  2. How to Manually Eject a Stuck Disc in a PlayStation 5: passo 2, imagem 1 %32 How to Manually Eject a Stuck Disc in a PlayStation 5: passo 2, imagem 2 %32 How to Manually Eject a Stuck Disc in a PlayStation 5: passo 2, imagem 3 %32
    • If you are using a stand to hold your PlayStation, locate the screw at the bottom.
    • Using the flathead screwdriver, unscrew the 5mm Phillips screw from the base.
    • Remove the base, and place it off to the side.
  3. How to Manually Eject a Stuck Disc in a PlayStation 5: passo 3, imagem 1 %32 How to Manually Eject a Stuck Disc in a PlayStation 5: passo 3, imagem 2 %32 How to Manually Eject a Stuck Disc in a PlayStation 5: passo 3, imagem 3 %32
    • Place the PlayStation on the side without the PlayStation logo.
    • Pull up on the top right corner of the PlayStation . This corner can be found diagonally across from the disc tray. Pull the cover toward the disc tray, in a diagonal direction.
    • To remove the white cover, it may take some force.
  4. How to Manually Eject a Stuck Disc in a PlayStation 5: passo 4, imagem 1 %32 How to Manually Eject a Stuck Disc in a PlayStation 5: passo 4, imagem 2 %32
    • Poke a hole through the black sticker with the Philip's head screwdriver or spudger.
    • Use the screwdriver as a key to turn the screw inside the black sticker clockwise.
    • The disc should come out after several turns.
Conclusão
7 outras pessoas executaram este guia.
Jason Pinto
Membro desde: 01/10/21
283 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 93
Últimos 30 dias: 433
Duração total: 7,089
