Ir para o conteúdo principal
How to Manually Eject a Stuck Disc in a PlayStation 4
O que você precisa
  1. How to Manually Eject a Stuck Disc in a PlayStation 4, Removing the Cover: passo 1, imagem 1 %32 How to Manually Eject a Stuck Disc in a PlayStation 4, Removing the Cover: passo 1, imagem 2 %32
    • Use your hands to remove the shiny part of the PS4 cover. It should come off rather easily.
    • As you can see in the second image, the cover should just pull of with ease, and a little force.
    • IF YOU ARE STRUGGLING TO REMOVE THIS COVER, PLACE THE PLAY-STATION ON A RAISED LEDGE TO GIVE YOURSELF A LITTLE MORE LEVERAGE
  2. How to Manually Eject a Stuck Disc in a PlayStation 4, Locating Phillips Screw: passo 2, imagem 1 %32
    • There is a small black screw located in-between the vents. You will see two sections of tightly packed slots and on single slot somewhat separated. This is where the screw is located.
    • PLEASE BE CAREFUL WITH THIS SCREW AS IT IS VERY EASY TO BE ROUNDED OFF.
  3. How to Manually Eject a Stuck Disc in a PlayStation 4, Rotate Counter-clockwise: passo 3, imagem 1 %32
    • Use a Phillips screwdriver and rotate the screw counter-clockwise. This shouldn't require very much pressure and you should see the stuck disc slowly come out of its slot after a few twists.
    • THE MORE PRESSURE THAT YOU USE, THE MORE CHANCE YOU RUN OF ROUNDING OFF THE HEAD
    • That is it! You are now done!
Conclusão
17 outras pessoas executaram este guia.
Kyle Webb
Membro desde: 05/07/19
1.181 Reputação
Autoria de 1 guia
4 comentários
Very informative! Even though I resolved my disc issue the other way that you said, I wanted to do it this way after, just in case I come across the issue again, and it was very easy to do following your guide. Thanks!
MobGuru - Responder
Does this method work for the CUH-1215a model?
james_frazier16 - Responder
Not Wirkung Disc is still in!
Detlev Szarafinski - Responder
Look for a screw with the PlayStation symbol on it. With a screwdriver, turn the screw counterclockwise to remove it from the hard disk drive (HDD).
Pull the HDD part-way out from the console, revealing the manual eject hole.
Insert a screwdriver inside the manual eject hole, turning clockwise to release the disc.
blaczacthasage - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 51
Últimos 7 dias: 283
Últimos 30 dias: 1,414
Duração total: 49,005
