Ir para o conteúdo principal
How to Manually Configure Timer Relay Box
O que você precisa
  1. How to Manually Configure Timer Relay Box, Access Config files: passo 1, imagem 1 %32
    • Connect the microcontroller to any computer.
    • The device will pop up as a removable disk. Open the drive.
    • Open the config folder
  2. How to Manually Configure Timer Relay Box, Reconfigure Delay Settings: passo 2, imagem 1 %32 How to Manually Configure Timer Relay Box, Reconfigure Delay Settings: passo 2, imagem 2 %32 How to Manually Configure Timer Relay Box, Reconfigure Delay Settings: passo 2, imagem 3 %32
    • Open trigger.py in any plain text editor.
    • Edit the value (seconds) to change the delay before the device is powered on.
    • Open power.py in any plain text editor.
    • Change the value (seconds) to change the delay the device is powered on for.
Conclusão
Reassemble the device.
James Schreiber
Membro desde: 02/10/22
230 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 20
Ao todo: 140
