Ir para o conteúdo principal
How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill
O que você precisa
  1. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill, How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: passo 1, imagem 1 %32
    • Unplug the treadmill from the wall outlet before you begin.
    • Loosen the screws in the deck of the treadmill at the edge of the machine using a screwdriver.
  2. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: passo 2, imagem 1 %32
    • Gently lift the belt.
  3. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: passo 3, imagem 1 %32
    • Take a clean cloth to wipe out any dust or debris.
  4. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: passo 4, imagem 1 %32
    • Apply lubricant under the belt, starting from the center and working your way to the edge.
    • Wear gloves as the lubricant is filled with chemicals.
  5. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: passo 5, imagem 1 %32
    • Tighten the screws in the treadmill deck using a screwdriver.
  6. How to Lubricate the Belt on a Horizon Fitness TempoT611T Treadmill: passo 6, imagem 1 %32
    • Start the treadmill again and ensure it works without creaking noises.
Conclusão
You did it! Oiling your treadmill is an essential maintenance task that ensures the longevity and optimal performance of your equipment. Regularly oiling the machine helps to reduce friction, noise, and wear and tear on the moving parts, making your workouts safer and more comfortable. Neglecting this task can lead to serious damage to your treadmill, which can be expensive to repair or replace. Therefore, it is recommended that you oil your treadmill every three to six months, depending on how frequently you use it. By taking good care of your equipment, you can enjoy a smooth and hassle-free treadmill workout for years to come.
Uma outra pessoa concluiu este guia.
Batul Ismail
Membro desde: 05/25/23
133 Reputação
Autoria de 1 guia
Equipe
York University, Team A-4, Allen Summer 2023 Membro de York University, Team A-4, Allen Summer 2023
YORK-ALLEN-SU23SAG4
Membros da 2
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 136
