Ir para o conteúdo principal
How to Lubricate a Rusted Measuring Tape
O que você precisa
  1. How to Lubricate a Rusted Measuring Tape, How to Lubricate a Rusted Measuring Tape: passo 1, imagem 1 %32
    • Loosen and remove the 9.5 mm screw using a Phillips #1 screwdriver.
    • Remove the belt clip.
    • Use a small bowl or a towel to keep the screws and other pieces of the measuring tape in one place so the hardware does not get lost.
    • Measuring tape screws can vary depending on the brand. Inspect the size and type of the screws to determine the size and type of screw driver needed.
  2. How to Lubricate a Rusted Measuring Tape: passo 2, imagem 1 %32
    • Gently slide off or separate the plastic cover from the measuring tape.
    • Not all measuring tapes have an outer case. If no outer case is present, proceed to next step.
  3. How to Lubricate a Rusted Measuring Tape: passo 3, imagem 1 %32
    • Remove the 15.7 mm screw(s) of the measuring tape case with the Phillips #1 screwdriver.
    • Depending on the brand of the measuring tape, there may be more than one Phillips head screw holding the case together.
  4. How to Lubricate a Rusted Measuring Tape: passo 4, imagem 1 %32
    • Carefully open the measuring tape case by hand.
    • If the case is difficult to separate by hand, use a small flathead screwdriver to gently pry the casing apart. Do not use excessive force as it may break the plastic casing.
    • Hold the measuring tape firmly while opening the case, keeping a good grip on both halves. Gently slide a finger inside to hold the spring and tape case so it does not move out of place or unravel.
  5. How to Lubricate a Rusted Measuring Tape: passo 5, imagem 1 %32
    • The small openings in the interior case that holds the tape and spring is where the lubricant (WD-40) will be applied.
  6. How to Lubricate a Rusted Measuring Tape: passo 6, imagem 1 %32
    • Apply a small amount of lubricant (WD-40) at a time while periodically pulling the measuring tape in and out slowly to spread the lubricant.
    • Maintain gentle pressure on internal casing during movement to keep the spring and tape from moving out of position or unraveling.
Conclusão
To put your measuring tape back together, follow these steps in reverse order. Make sure all parts are secure before snapping the case shut and screws are hand tightened. Once put back together, test the measuring tape by pulling the tape out and allowing it to retract.
Miles Kim
Membro desde: 04/25/24
133 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 3-4, Whithaus Spring 2024 Membro de UC Davis, Team 3-4, Whithaus Spring 2024
UCD-WHITHAUS-S24S3G4
3 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 291
