Introdução
If the vacuum is malfunctioning, water will be fed into the air pump causing it to rust and seize.
Peças
Não são necessárias peças.
Move the brewer so that the bottom is easily accessible.
Unscrew the five 4mm silver diagrammed screws using a #2 Philips Head screwdriver.
14 outras pessoas concluíram este guia.
17 comentários
I cant get the little screws off of the vacuum. I broke 3 screwdrivers. Could they be glued?
After you take the white piece of the vaccuum pump off, you will see the black rubber diaphragm just below. DO NOT REMOVE the black rubber diaphragm. It is not necessary to remove this piece, and it will NOT BE POSSIBLE to re-assemble the pump after you remove it. Just clear any obstructions and put the white piece with the tube back on.
I removed the black diaphragm before I realized what it was, and now my Keurig K75 Platinum ($) is heading to the landfill. Hopefully this will prevent somebody else from making that same mistake.
Dang... didn't expect it to work... but it did!!
This worked for me. When i took off the white piece 2 of the 3 little rubbery, indented pieces were recessed and one was popped out a bit. I pushed them all in and it seemingly fixed the problem. I ran it about three times so far and it is working properly so hopefully it stays working for a while.
