Introdução
This is a step-by-step installation guide so you can have a new LED rear fog light for your Scion tC in no time!
O que você precisa
Remove the screws holding the bulbless rear reflector in place and then remove the entire rear reflector assembly.
Carefully drill a hole using the drill bit included in the package. We recommend drilling directly in the center of the assembly, using the center raised portion as a guide line so the hole isn't misaligned.
Try to slightly shave down four corners of the socket in small increments so the socket can fit snugly in the housing.
Locate the tail light and brake light mode wires. You will be tapping to these wires for power.
The color combo of the wires may differ among production batches, so we recommend that you double-check and test which wire is what function. You can easily test the socket by inserting the bulb and touching the wires directly to your car's battery. Mark which wire is the brighter mode, parking light mode, and negative.
Tap the negative wire from the socket to the ground and the black wire of the stock parking light.
Test to make sure your Scion tC LED rear fog light works and enjoy!
Um comentário
This is for the wrong model Scion tC. Please edit the category and place in the 2014-15 category.
