Ir para o conteúdo principal
How to Install Handlebar Tape
O que você precisa
  1. How to Install Handlebar Tape, How to Install Handlebar Tape: passo 1, imagem 1 %32 How to Install Handlebar Tape, How to Install Handlebar Tape: passo 1, imagem 2 %32
    • Flip the hood of the brake lever upwards.
  2. How to Install Handlebar Tape: passo 2, imagem 1 %32 How to Install Handlebar Tape: passo 2, imagem 2 %32 How to Install Handlebar Tape: passo 2, imagem 3 %32
    • Peel off the adhesive covering from the back of the bar tape.
    • Place one end of the bar tape around the handlebar, making sure to leave a half inch extended past the end of the handlebar.
    • Begin tightly wrapping the bar tape clockwise around the handlebar so that the bar tape overlaps itself slightly.
  3. How to Install Handlebar Tape: passo 3, imagem 1 %32 How to Install Handlebar Tape: passo 3, imagem 2 %32
    • After a few wraps, tuck the extra bar tape into the end of the handlebar and firmly push in the bar end plug.
  4. How to Install Handlebar Tape: passo 4, imagem 1 %32 How to Install Handlebar Tape: passo 4, imagem 2 %32
    • Continue to tightly wrap the bar tape around the bar as evenly as possible.
    • Make sure the adhesive on the back of the bar tape is making contact with the metal handlebar.
  5. How to Install Handlebar Tape: passo 5, imagem 1 %32 How to Install Handlebar Tape: passo 5, imagem 2 %32 How to Install Handlebar Tape: passo 5, imagem 3 %32
    • Take the extra piece of bar tape provided and cut it to fit the back of the brake lever.
  6. How to Install Handlebar Tape: passo 6, imagem 1 %32 How to Install Handlebar Tape: passo 6, imagem 2 %32 How to Install Handlebar Tape: passo 6, imagem 3 %32
    • Continue wrapping over lever.
    • Keep in mind the tightness and evenness of space between each wrap as you continue.
  7. How to Install Handlebar Tape: passo 7, imagem 1 %32 How to Install Handlebar Tape: passo 7, imagem 2 %32
    • Flip the break lever hood back down and continue.
  8. How to Install Handlebar Tape: passo 8, imagem 1 %32 How to Install Handlebar Tape: passo 8, imagem 2 %32
    • Stop wrapping about 2 inches from stem.
  9. How to Install Handlebar Tape: passo 9, imagem 1 %32 How to Install Handlebar Tape: passo 9, imagem 2 %32 How to Install Handlebar Tape: passo 9, imagem 3 %32
    • Cut the bar tape diagonally at an approximately 60 degree angle.
  10. How to Install Handlebar Tape: passo 10, imagem 1 %32
    • Finish the wrap.
    • The cut should make the end of the bar tape a straight line.
  11. How to Install Handlebar Tape: passo 11, imagem 1 %32 How to Install Handlebar Tape: passo 11, imagem 2 %32 How to Install Handlebar Tape: passo 11, imagem 3 %32
    • Use the electrical tape provided to tightly secure the end of the wrap.
  12. How to Install Handlebar Tape: passo 12, imagem 1 %32 How to Install Handlebar Tape: passo 12, imagem 2 %32 How to Install Handlebar Tape: passo 12, imagem 3 %32
    • Press down on electrical tape to secure it.
  13. How to Install Handlebar Tape: passo 13, imagem 1 %32 How to Install Handlebar Tape: passo 13, imagem 2 %32 How to Install Handlebar Tape: passo 13, imagem 3 %32
    • Repeat steps 1-12 on the other side, now wrapping counterclockwise.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Elizabeth Hall
Membro desde: 04/28/17
131 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S2-G7, Cole Spring 2017 Membro de UC Davis, Team S2-G7, Cole Spring 2017
UCD-COLE-S17S2G7
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 44
Duração total: 4,039
