Ir para o conteúdo principal
How to Increase the Waist Size of Jeans
O que você precisa
  1. How to Increase the Waist Size of Jeans, How to Increase the Waist Size of Jeans: passo 1, imagem 1 %32
    • Lay the jeans on a flat surface.
    • Use a measuring tape to measure the waistband of the jeans from one hip to hip.
  2. How to Increase the Waist Size of Jeans: passo 2, imagem 1 %32
    • With the measuring tape, measure your own waistline from hip to hip.
  3. How to Increase the Waist Size of Jeans: passo 3, imagem 1 %32
    • Calculate the difference between your waistline and the waistband measurements.
    • Mark 1/4 of the difference on each side of the waistband with a pencil.
    • For example, if the difference is 1 inch, mark 1/4 inch on each hip.
  4. How to Increase the Waist Size of Jeans: passo 4, imagem 1 %32 How to Increase the Waist Size of Jeans: passo 4, imagem 2 %32
    • Use sewing scissors to cut from 1/2 inch below the waistband to the marking made in Step 3.
    • Scissors may be sharp and should be used carefully.
  5. How to Increase the Waist Size of Jeans: passo 5, imagem 1 %32 How to Increase the Waist Size of Jeans: passo 5, imagem 2 %32
    • Measure the elastic to fit the space that was removed from the waistband with an extra 1/2 inch on each end.
    • Cut the elastic where it was measured.
  6. How to Increase the Waist Size of Jeans: passo 6, imagem 1 %32 How to Increase the Waist Size of Jeans: passo 6, imagem 2 %32
    • Insert an arms-length piece of thread through the needle's eye.
    • Pull it through the needle so both ends of the thread meet.
    • Tie a knot at the end of the thread.
    • The sewing needle is sharp and should be used carefully.
  7. How to Increase the Waist Size of Jeans: passo 7, imagem 1 %32 How to Increase the Waist Size of Jeans: passo 7, imagem 2 %32
    • Sew each end of the elastic on the inside of the waistband.
    • This can be done by inserting the needle back and forth through the elastic and jean waistband. Refer to this guide for information on how to hand sew a straight stitch.
  8. How to Increase the Waist Size of Jeans: passo 8, imagem 1 %32
    • Tie a knot at the end of the thread when you finish sewing. Cut off the excess thread.
    • Repeat steps 3-8 on the alternate side of the waistband.
Conclusão
There you have it, an up-cycled pair of jeans that you can wear proudly instead of throwing away!
Uma outra pessoa concluiu este guia.
Katy Lawlor
Membro desde: 04/26/24
175 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 4-2, Whithaus Spring 2024 Membro de UC Davis, Team 4-2, Whithaus Spring 2024
UCD-WHITHAUS-S24S4G2
3 Membros
1 Guia de autoria
1Comentário do guia
Porque no lo traducen en español
Alberto - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 82
Ao todo: 868
