Ir para o conteúdo principal
How to Hem a Skirt
O que você precisa
  1. How to Hem a Skirt, How to Hem a Skirt: passo 1, imagem 1 %32
    • Turn the garment inside out.
    • Inspect the hem: Are there any bulky regions along the hem or is it even all across? Is the hem straight or does it have curves?
  2. How to Hem a Skirt: passo 2, imagem 1 %32
    • If your skirt has an existing hem, use seam ripper to remove current hem.
    • Place the pointed end in each stitch and cut it using the blade edge on the seam ripper.
    • Be sure not to rip the actual garment.
    • The example skirt did not have an existing hem.
  3. How to Hem a Skirt: passo 3, imagem 1 %32 How to Hem a Skirt: passo 3, imagem 2 %32 How to Hem a Skirt: passo 3, imagem 3 %32
    • If the skirt is being shortened, wear the skirt inside out and measure the desired length.
    • Use sewing chalk to mark the length.
    • Pin up the fabric along the desired chalk line.
    • If you are only adding a hem, measure and fold 1/2 an inch up from the bottom of the skirt and pin along the edge.
    • You want to wear the skirt inside out so the hem is not on the outside of the skirt.
    • It may help to have a partner mark the desired length of the skirt while you are wearing it.
  4. How to Hem a Skirt: passo 4, imagem 1 %32 How to Hem a Skirt: passo 4, imagem 2 %32 How to Hem a Skirt: passo 4, imagem 3 %32
    • Thread the needle with matching thread.
    • Start with a Backstitch to secure the thread.
    • Stitch along the hem, avoiding the pins.
    • Create a backstitch once you meet the place where you began.
    • For the example images, a darker thread was used for better visibility.
  5. How to Hem a Skirt: passo 5, imagem 1 %32 How to Hem a Skirt: passo 5, imagem 2 %32
    • Cut the thread to detach from needle.
    • Cut any excess thread.
  6. How to Hem a Skirt: passo 6, imagem 1 %32
    • Turn the skirt right side out.
    • Inspect the hem to ensure there are no gaps.
    • Try on skirt for fit.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Safiah Nemr
Membro desde: 02/01/24
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-3, Andersen Winter 2024 Membro de UC Davis, Team 1-3, Andersen Winter 2024
UCD-ANDERSEN-W24S1G3
3 Membros
Autoria de 2 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 257
