Ir para o conteúdo principal
How to Hem Sweatpants
O que você precisa
  1. How to Hem Sweatpants, How to Hem Sweatpants: passo 1, imagem 1 %32 How to Hem Sweatpants, How to Hem Sweatpants: passo 1, imagem 2 %32
    • Use the seam ripper to remove the seams along the hem of the bottom of the pants.
  2. How to Hem Sweatpants: passo 2, imagem 1 %32
    • Remove the elastic band from the pants. Keep the elastic for later.
  3. How to Hem Sweatpants: passo 3, imagem 1 %32
    • Place pins where you want the pants to end.
  4. How to Hem Sweatpants: passo 4, imagem 1 %32 How to Hem Sweatpants: passo 4, imagem 2 %32 How to Hem Sweatpants: passo 4, imagem 3 %32
    • Measure the length of the cuff.
    • Measure how long the pants need to be cut.
    • Keeping in mind a small length below the pins for the new cuff, mark where you want to cut with your washable marker.
  5. How to Hem Sweatpants: passo 5, imagem 1 %32
    • Using the fabric scissors, cut along the line you marked, making sure to keep a straight and steady line.
  6. How to Hem Sweatpants: passo 6, imagem 1 %32
    • Fold the new end of the pants outward, at a minimum of double the length of the elastic band.
  7. How to Hem Sweatpants: passo 7, imagem 1 %32 How to Hem Sweatpants: passo 7, imagem 2 %32
    • Place the elastic band on top of the fold from the previous step.
    • Place the top of the elastic along the pin line.
    • Using the needle and thread, sew both ends of the elastic band to the seam running vertically up and down the pant leg.
  8. How to Hem Sweatpants: passo 8, imagem 1 %32 How to Hem Sweatpants: passo 8, imagem 2 %32
    • Fold the top of the folded fabric section back over the elastic, using the pins as the top line.
    • Place pins along the bottom of the new fold to keep the fabric in place.
  9. How to Hem Sweatpants: passo 9, imagem 1 %32 How to Hem Sweatpants: passo 9, imagem 2 %32 How to Hem Sweatpants: passo 9, imagem 3 %32
    • Sew a new hem along the line created by the new pins. You can either hand-sew or use a sewing machine.
    • Sew ONLY along the new pins placed in the previous step. Do not sew along the first row of pins created at the beginning.
    • Once the sewing is complete, remove all the pins and undo the first fold.
    • The last photo provides a sample of the finished product.
Linha de Chegada
Uma outra pessoa concluiu este guia.
1Comentário do guia
Thanks very much for this tutorial because at 5’ I have to shorten everything. Now I can alter sweatpants that are made for 6’ tall people.
Ruthann45 - Responder
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 51
Últimos 30 dias: 220
Ao todo: 14,141
