Ir para o conteúdo principal
How to Hem Pants by Hand-Sewing
O que você precisa
  1. How to Hem Pants by Hand-Sewing, How to Hem Pants by Hand-Sewing: passo 1, imagem 1 %32
    • Wear the pants and fold the hem up until you get your desired length.
  2. How to Hem Pants by Hand-Sewing: passo 2, imagem 1 %32
    • Remove the pants, making sure that the folded hem remains fixed.
    • Lay the pants down on a table and measure the length from the original hem to the folded edge.
    • Make sure to take note of all of your measurements.
  3. How to Hem Pants by Hand-Sewing: passo 3, imagem 1 %32
    • Turn the pants inside out, and unfold the folded edge.
    • Starting from the original hem, measure out the length of what will be your new hem.
    • The length you will need for this step would be the length you measured out from the previous step.
    • Using your fabric marker, draw a line marking where your new hem would be.
  4. How to Hem Pants by Hand-Sewing: passo 4, imagem 1 %32
    • Starting from the line you just created, measure out 1 inch and mark with a line.
  5. How to Hem Pants by Hand-Sewing: passo 5, imagem 1 %32
    • Using the 1 inch line as your guide, cut off the extra fabric.
  6. How to Hem Pants by Hand-Sewing: passo 6, imagem 1 %32 How to Hem Pants by Hand-Sewing: passo 6, imagem 2 %32
    • Fold the raw edge up to the new hem line.
    • Fold it again along the new hem line, so that the raw edge is now inside the fold.
  7. How to Hem Pants by Hand-Sewing: passo 7, imagem 1 %32 How to Hem Pants by Hand-Sewing: passo 7, imagem 2 %32
    • Place a sewing pin parallel to the fold to make sure that the fold stays in place.
    • Fold and pin all the way around to create your new hem.
  8. How to Hem Pants by Hand-Sewing: passo 8, imagem 1 %32
    • Have your needle threaded and ready to go.
    • Sew the fold close to create a new hem; try to keep your stitches small and even.
    • White thread was used instead of black to make the stitches more evident in the pictures.
  9. How to Hem Pants by Hand-Sewing: passo 9, imagem 1 %32 How to Hem Pants by Hand-Sewing: passo 9, imagem 2 %32 How to Hem Pants by Hand-Sewing: passo 9, imagem 3 %32
    • Once you're done stitching, tie off the thread by creating a knot towards the end of the string.
    • Cut off the excess string above the knot.
    • Remove all of the sewing pins.
    • Repeat steps 3 to 8 for the other pant leg using the same measurements, and then you're officially done!
Conclusão
18 outras pessoas executaram este guia.
Irish Pellas
Membro desde: 09/29/15
709 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-5, Green Fall 2015 Membro de Cal Poly, Team 15-5, Green Fall 2015
CPSU-GREEN-F15S15G5
Membros da 4
Autoria de 14 guias
Um comentário
Thank you for this guide! The only thing I am uncertain about is how determine a good length for the pants. I read in another guide that it would be good to measure with shoes on. So that the pant leg grazes the shoe. Can you recommend the same?
Christin Kalina - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 33
Últimos 7 dias: 216
Últimos 30 dias: 1,025
Duração total: 138,913
