Ir para o conteúdo principal
How to Hard Reset your HTC myTouch 3G
  1. How to Hard Reset your HTC myTouch 3G, How to Hard Reset your HTC myTouch 3G: passo 1, imagem 1 %32 How to Hard Reset your HTC myTouch 3G, How to Hard Reset your HTC myTouch 3G: passo 1, imagem 2 %32 How to Hard Reset your HTC myTouch 3G, How to Hard Reset your HTC myTouch 3G: passo 1, imagem 3 %32
    • Start by turning off the phone.
    • Hold the Home and End keys for ten to thirty seconds, or until the home recovery display appears.
  2. How to Hard Reset your HTC myTouch 3G: passo 2, imagem 1 %32 How to Hard Reset your HTC myTouch 3G: passo 2, imagem 2 %32
    • Press the Home and End button once again to open the Recovery Options menu.
  3. How to Hard Reset your HTC myTouch 3G: passo 3, imagem 1 %32 How to Hard Reset your HTC myTouch 3G: passo 3, imagem 2 %32
    • Using the trackball, scroll to and select "wipe data/factory reset".
  4. How to Hard Reset your HTC myTouch 3G: passo 4, imagem 1 %32 How to Hard Reset your HTC myTouch 3G: passo 4, imagem 2 %32
    • Once the reset is complete, scroll back to "reboot system now".
Conclusão
Warning: This process will wipe out any data on the phone.
9 outras pessoas executaram este guia.
Erik
Membro desde: 09/17/12
96 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 2-9, Propen Fall 2012 Membro de Cal Poly, Team 2-9, Propen Fall 2012
CPSU-PROPEN-F12S2G9
Membros da 3
Autoria de 10 guias
3 comentários
this guide is soo good but my only problem is dat de scroll key is able to scroll through de options at the recovery page but unable to select. how do i select the "wipe data/factory reset option
David Mensah - Responder
i have the same problem, can you have a solution?
Raúl Torres Cázares -
Muchas gracias me ha servido mucho hace tiempo no trataba con estas reliquias que fueron la antesala de los equipos android de ahora
migueldan7 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 22,655
