Ir para o conteúdo principal
How to Hand Sew Patches Onto a Garment
O que você precisa
  1. How to Hand Sew Patches Onto a Garment, How to Hand Sew Patches Onto a Garment: passo 1, imagem 1 %32
    • Place the cardboard separator in between the layers of your chosen garment.
    • This helps to avoid stitching both sides of the garment together.
  2. How to Hand Sew Patches Onto a Garment: passo 2, imagem 1 %32
    • Choose a color of thread that matches or contrasts with the color of your patch.
  3. How to Hand Sew Patches Onto a Garment: passo 3, imagem 1 %32 How to Hand Sew Patches Onto a Garment: passo 3, imagem 2 %32
    • Choose where you’d like the patch to sit on the garment.
    • To help with stability, use pins and iron the garment to maintain the position of the patch.
  4. How to Hand Sew Patches Onto a Garment: passo 4, imagem 1 %32 How to Hand Sew Patches Onto a Garment: passo 4, imagem 2 %32
    • Push the thread through the eye of the needle.
    • To prevent fraying, twist the ends of the thread to tighten it.
  5. How to Hand Sew Patches Onto a Garment: passo 5, imagem 1 %32 How to Hand Sew Patches Onto a Garment: passo 5, imagem 2 %32 How to Hand Sew Patches Onto a Garment: passo 5, imagem 3 %32
    • Insert the needle through the backside of the shirt and patch.
    • Pull the needle until the thread is taut.
    • Insert the needle through the outside of the shirt and patch, at the length you’d like your stitch to be.
    • Pull the needle again until the thread is taut.
  6. How to Hand Sew Patches Onto a Garment: passo 6, imagem 1 %32 How to Hand Sew Patches Onto a Garment: passo 6, imagem 2 %32 How to Hand Sew Patches Onto a Garment: passo 6, imagem 3 %32
    • On the backside, insert the needle at a similar distance to the previous stitch, away from the previous stitch.
    • Insert the needle at the end of the previous stitch; this will be stitching backwards.
  7. How to Hand Sew Patches Onto a Garment: passo 7, imagem 1 %32 How to Hand Sew Patches Onto a Garment: passo 7, imagem 2 %32 How to Hand Sew Patches Onto a Garment: passo 7, imagem 3 %32
    • Lace the needle through the extra fabric of the shirt that is covered by the patch.
    • Hold both ends of your thread and rotate it around the needle twice.
    • Create a loop using the thread and pull your needle through the loop.
    • Pull until the knot has formed (no extra thread is leftover).
    • Cut the thread with 1-2 inches to spare.
  8. How to Hand Sew Patches Onto a Garment: passo 8, imagem 1 %32
    • Finished Product!
Linha de Chegada
Uma outra pessoa concluiu este guia.
Shannon Ikemiya
Membro desde: 04/24/24
178 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-1, Whithaus Spring 2024 Membro de UC Davis, Team 2-1, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G1
4 Membros
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 52
Ao todo: 448
