Ir para o conteúdo principal
How to Hand Sew A Small Hole in Clothing
O que você precisa
  1. How to Hand Sew A Small Hole in Clothing, How to Hand Sew A Small Hole in Clothing: passo 1, imagem 1 %32
    • Grabbing a long piece of thread, insert it into the eye of the needle.
    • Make sure the thread is long enough to sew the entire hole.
    • If it happens to be that your thread is too short, you will need to take a look at step 8 to properly secure the thread to the piece of clothing. Then, you would grab a second thread and repeat steps 1-3 before continuing the sewing process.
  2. How to Hand Sew A Small Hole in Clothing: passo 2, imagem 1 %32
    • Align one end of the thread to the other end of the thread.
    • To keep it simple, this step is folding the thread in half. This allows the stitching to be more secure and less likely to de-thread, especially when washing your clothes.
  3. How to Hand Sew A Small Hole in Clothing: passo 3, imagem 1 %32 How to Hand Sew A Small Hole in Clothing: passo 3, imagem 2 %32 How to Hand Sew A Small Hole in Clothing: passo 3, imagem 3 %32
    • With the two ends in hand, tie a double knot to form one single thread.
    • You may need to tie more than two knots in order for it to hold in place when sewing.
  4. How to Hand Sew A Small Hole in Clothing: passo 4, imagem 1 %32 How to Hand Sew A Small Hole in Clothing: passo 4, imagem 2 %32 How to Hand Sew A Small Hole in Clothing: passo 4, imagem 3 %32
    • Fold the clothing inside out. From the hole, pinch the two sides together, making sure the outside of the clothing is even and smooth.
    • We will be sewing the inside of the clothing. However, you want to make sure the outside of the clothing is even. If not, the hole will not be sewn correctly.
  5. How to Hand Sew A Small Hole in Clothing: passo 5, imagem 1 %32 How to Hand Sew A Small Hole in Clothing: passo 5, imagem 2 %32 How to Hand Sew A Small Hole in Clothing: passo 5, imagem 3 %32
    • Starting on one end of the hole, poke the needle through the clothing, passing the thread and needle to the other side of the hole. The double knot should not move from the original side you began with, but instead, be held in place. Make sure to pull the thread and needle firmly in order to seal the hole properly.
    • If the double knot goes through the other side, take out the needle from the clothing and continue to tie a few more knots. Do this until the knot does not pass through the other side of the hole.
    • Keep the length of the stitching small and the distance rather close to each other for a more precise stitch.
  6. How to Hand Sew A Small Hole in Clothing: passo 6, imagem 1 %32 How to Hand Sew A Small Hole in Clothing: passo 6, imagem 2 %32 How to Hand Sew A Small Hole in Clothing: passo 6, imagem 3 %32
    • Then, from the other side, poke another hole and pass the thread to the side originally started on, following the same process in step 5.
    • Make sure the holes poked with the thread form a straight line for a neater appearance.
  7. How to Hand Sew A Small Hole in Clothing: passo 7, imagem 1 %32 How to Hand Sew A Small Hole in Clothing: passo 7, imagem 2 %32
    • Continue this process in a zig-zag motion until the hole is completely sewn.
  8. How to Hand Sew A Small Hole in Clothing: passo 8, imagem 1 %32 How to Hand Sew A Small Hole in Clothing: passo 8, imagem 2 %32 How to Hand Sew A Small Hole in Clothing: passo 8, imagem 3 %32
    • At the end, use the needle to loop the thread, tying a few knots to hold the stitching in place.
    • Cut any remaining thread with a pair of scissors.
    • Tie the knots as close to the clothing as possible so that the thread doesn’t hang and de-thread the stitching when pulled.
Conclusão
Thank you for reading my guide and I hoped it helped you understand the basics of hand sewing. Don’t worry if you can’t get it right the first time, practice makes perfect! Happy sewing :)
Aviance Davalos
Membro desde: 10/20/20
157 Reputação
Autoria de 1 guia
Equipe
Um comentário
What kind of stitch is this? Can you highlight it at the top. Thanks!
Jake Schneider - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 43
Ao todo: 7,065
