Ir para o conteúdo principal
How to Format a drive in Windows 7-10
O que você precisa
  1. How to Format a drive in Windows 7-10, Open File Explorer: passo 1, imagem 1 %32
    • Open File Explorer.
    • You can do that from either of the red highlighted spots, or search for "File Explorer."
  2. How to Format a drive in Windows 7-10, Open the Format Menu: passo 2, imagem 1 %32 How to Format a drive in Windows 7-10, Open the Format Menu: passo 2, imagem 2 %32
    • Right-Click on the drive you want to format, and click format
    • This is what should pop up.
  3. How to Format a drive in Windows 7-10, Format your drive: passo 3, imagem 1 %32
    • if you will be using the drive for Windows, format it as NTFS. If you need a multi-OS drive, exFAT or FAT32 is recommended. However, keep in mind FAT32 has a 4GB limit on files.
    • Use default allocation size.
    • If you want to rename your drive put the new name here.
    • Start the format. When It's done, you can close all the windows, and you are done.
Linha de Chegada
6 outras pessoas executaram este guia.
George A.
Membro desde: 12/07/16
21.960 Reputação
Autoria de 4 guias
Equipe
Community Protectors Membro de Community Protectors
Community
Membros da 19
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 78
Duração total: 1,201
